yellaasian Posted October 23, 2004 Report Posted October 23, 2004 can you make the brightness button when pressed disable the pallet lock feature so you can use the generic bump buttons without unlocking the pallets currently if just stays at the last attribute pressed Quote
K-Nine Posted January 25, 2005 Report Posted January 25, 2005 Presumably you mean the palette lock feature as far as the flash buttons are concerned but NOT the palette lock as far as what is displayed on the monitor screen ? Wouldn't you then have a potential for confusion as the buttons are doing one thing but the monitor is showing something else, or do you change what is on the monitor screen after you press the Brightness button ? Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
yellaasian Posted January 25, 2005 Author Report Posted January 25, 2005 maybe change it to a different page that says Conventional Bump Buttons in the center of the screen I thing this feature would make this board that much more powerful for the price The brightness button would also control the mover brightness with the wheel which should not be confusing 8) Quote
Paul Posted April 4, 2005 Report Posted April 4, 2005 Frog Reference 5518 - Brightness button to be added to lockable palettes screens (Colour/Beamshape/Position), to allow Channel Flash or SX buttons to be used for their normal function. We need to decide what the monitor should display when locked on 'Brightness', since there are no Brightness palettes. Any suggestions? Quote
ice Posted April 4, 2005 Report Posted April 4, 2005 "Pallets locked, normal flash function" ? Quote > 500 posts, time for a new T-shirt?
