dominicgross Posted September 28, 2002 Report Posted September 28, 2002 hey, is it possible to input a name/text for a scene or sub on the frog - the option is on screen- but i can't get anything in there!! this might be a bug or just not exist... on the monitor output there is a column for name or text... i can''t seem to find a way to input anything into it.... help me out.... cheers, Dom Quote Dom Gross
Kirkup_xp Posted September 29, 2002 Report Posted September 29, 2002 Try hittting the F2 button (which happens to be the 'rename' function on a Windows PC) while you have the memory or sub selected. Magic. It also works the other way around. If you hit 'F2' with nothing selected, a requester will appear prompting you to select an item. Once selected, you can name it. Quote Peter Kirkup
K-Nine Posted September 30, 2002 Report Posted September 30, 2002 HI, Text naming of items was first added when palettes were introduced (Release 3, I think) and was extended to include memories, submasters, fixture groups and SX buttons (Mambo Frog). As the text field was not originally included on the memories or submaster screens, it was decided to provide a general naming function which could be applied to a variety of objects, hence the use of the F2 button. Ensure that the main LCD is showing one of the main screens (Memories, submasters, outputs), then press F2. A message is displayed asking you to select type of item to name ... For memories: press MEMORIES button, then enter the required memory number and ENTER. For submasters: select the required submaster page using the page up or page down buttons, then press the required submaster flash button. For palettes: press the required attribute button (COLOUR, BEAMSHAPE or POSITION), then press the required palette selection button. For fixture groups: press the GROUP button, then press the required group selection button. When you have selected the item to name, use the up/down and +/- keys to enter the text from the front panel, or use an external keyboard. Cheers, K-Nine. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Drunkenmunkey Posted March 31, 2004 Report Posted March 31, 2004 Hi peepz, I've connected my keyboard on the fat frog. (before i start the frog up) !When i make a submaster, for example submaster 1-3 i put on 'F2"on the frog,but i can't give it a name. What do i wrong??? Greetz Quote
ptheboris Posted November 2, 2004 Report Posted November 2, 2004 Hi Due to a really stupid get in arrangement I have had to programme for a show without the correct rig in place so have not actually seen the show lit as such. In order to save further time when I do finally get in and have chance to edit, is there anyway of naming memories using the Phantom Frog facility as my laptop will not allow me to? Paul Quote
sp Posted November 3, 2004 Report Posted November 3, 2004 Just select the memory on the stack > F2 > Memories > Enter Type in the name > Enter And for a submaster F2 > Submaster Flash Button> Type name > Enter sp Quote
ptheboris Posted November 11, 2004 Report Posted November 11, 2004 Thanks guys for the info. Got it all done and thankfully the editor saved the day as most of the work had been done when I finally came to see the show properly Paul Quote
Jos Posted January 21, 2008 Report Posted January 21, 2008 Greetings! I've been trying to figure out how to assign a name to a submaster on the Fat Frog. The problem is that when I'm on the submasters window, and I cycle through my columns it always skips the name field for some reason. I'm probably missing something pretty obvious though! If anyone could shed some light on this it would be greatly appreciated! Thanks in advance! Jos Quote 't Beest
Exstage T.S Posted February 20, 2009 Report Posted February 20, 2009 How do you select the memorys that you want to name ??? Thanks Quote Elliott Silk & Sam Raby Exstage Theatre Services www.exstagetheatreservices.co.uk
Paul Posted February 20, 2009 Report Posted February 20, 2009 Read the section on Naming Memories in the manual (Issue 6, page number '4-14'). Quote
joefrog Posted April 24, 2009 Report Posted April 24, 2009 I can't work out how to save a memory with a name. I see the names column, but the frog just skips over it, I have the keyboard. I was also wondering, is it possible to use a USB keyboard. With a ps2 to USB adapter? Quote
Kirkup_xp Posted May 6, 2009 Report Posted May 6, 2009 Hi Joe By looking at your signature I see that you've cracked this one - press F2 to open the Name popup, then follow the on-screen instructions. I hope this helps, Quote Peter Kirkup
