What does setting the Minimacs to sound activated mode actually require ?
If this is simply a matter of setting one of the fixture parameters to a particular value then you could always program that data into a submaster :)
as far as i am aware it involves physically scrolling through the menu on the actual mac to get it to the SA mode
Is there a way of setting moving lights to operated according to the sound input of the desk? (Does that make sense!?)
how would I set the minimacs to operate according to the sound input then? I dont understand the userguide on how to do it!!
I presume i'd also have a way of turning it on and off, say on a submaster?
Thanks again
Selecting S.A. on a minimac can be done by setting a specific value on the shutter-channel.
The manual specifies the exact value.
Standalone minimacs are synchronised to the master unit, who in itself is sound-triggered, hence they all move sync'ed to sound.
However, if you use dmx to set them to sound activation, they won't be sync'ed at all.
Looks kinda messy really.
If you require synchronised movement to sound, you will have to program a sound triggered routine on the desk itself.
  samcoombes said:
I can only see in the manual how to set them to SA mode using the martin controller.
If you look in the manual at page 40 (DMX Protocol), channel 1(shutter), you will see 168-177 (66-69%) Stand alone w/ music trigger.
It's not exactly the same as S.A., since the units won't be sync'ed.
  samcoombes said:
am i correct in thinking that I cannot make them operated by liasing with the Fat Frog Audio input?
You won't be able to feed the frog's audio input directly to the macs.
The way to use the audio input on the green thing is by writing a chase for the macs like you would normally, but using audio trigger instead.
K-nine will be much better in explaining the correct procedure though.
  samcoombes said:
oh yes, found it and tried it - they all went mad!!
Ideally wanted all 4 macs to do the smae thing in time with music - but don't think it's going to happen. :cry:
As I said, not sync'd
And they can't be, regular dmx is one-way only.
You will have to do it the hard way (base triggered chase on the Frog)
As suggested above ... if you want all the minimac fixtures to do the same thing in time with the music, and be controlled by the frog desk, then the best way is to program a chase memory and set the drive modifier to Bass. Ensure that the sound input is plugges into the back of the desk.
Alternatively, you could set the Drive modifier to beat and then get the operator to set the beat speed by tapping the step button when required.
For more info on this function .... CLICK HERE
Hi Sam,
the guys above set you up in the right and competent way!!! :twisted:
All you have to do is to program a chase memory including your minimacs and set times and trigger like you want. You DO NOT have to set the minimacs to any SA mode (SA sounds even shitty to me!!! :wink: F...up german history)
If you can´t deal with chase programming, try the FROG FUNCTION of the Frogs.
BUT REMEMBER all Desks and Movinglights only do what they are told!!! :twisted:
Cheers Sven
Sven Paulsen
Klangfarbe Vienna
And if you have any questions about the mini's, I'll see what I can do.
On a side note,
DMX induced stand alone w/ music trigger is indeed quite useless with more than one mac. Unfortunately, I don't really see how Martin could have done it any other way (apart from not implementing it at all).
Synchronised sound activation would require a single fixture designated as the master unit. In itself this would be possible.
Since it isn't possible to use a doubled link between fixtures (if we stick to the dmx standard), there's really no way for the master to communicate directly to the other fixtures while it is also connected to a Frog.
So it's not so much a badly implemented fixture, it's just not a very useful feature.
Unless you want them to move unsync'ed.
