I bought a fat frog off ebay and it has some quirks, first it takes a long time to turn on 10 minutes or longer. I used it for the first time in show and scenes i would program would change and some times the frog would black out all lights. any Ideas. Does it need service.
Have upgraded to latest software.
Well to me it would sound like it needed a service - 10 minutes is far too long, and all the problems.
Blacking out the lights - that's no good at all for your show. 8O
What did the seller have to say about the desk?
Did they say it was in perfect order? If so, then it seems they've got some questions to answer. :?:
sp
Can you let us know the serial number of the desk to give us some idea of it's age?
Also, is there anything displayed on the LCD or monitor during this 10 minute startup time?
Is there a floppy in your diskdrive?
Oh and that blacking out off all the lights is called a "feature" :P Just kiddin'; that's not normal if you're sure you're not doing anything which can cause that. Have you checked if your DMX output signal if good enough. Blackouts can easily be generated by faulty DMX wiring; max. 25 aparatus on each line, use DMX cable, NOT microphone; use a terminator and if you're making distances; use a proper (galvanic seperated) booster to get your signal to the other end of the line.
Here is the info on my fat frog serial number from the the desk info/super users menu 0073301 xxxxxxxx
serial number from back of console 0073301 xxxxxxxx
software version 9.6.1 7-4-2004
bios version 1.0.1 4-4-2001
When I plug in the frog the channel and sub flash buttons flash intermitantly and the sub page displays 88 for about 5 min then you can hear a drive spinning buttons continue to flash and 5 min or so later the frog will start up
Moderation: serial numbers removed.
HI,
As mentioned in my PM you have a few options available to you.
Please do not hesitate to contact me to discuss the matter further.
Keith Rogers
