Hockeybod Posted February 23, 2024 Report Posted February 23, 2024 Our school's Frog desk has started losing settings every time it's switched off, so I assume it's the coin cell battery/batteries. I have replaced them on a Jester, but haven't tackled a Frog. Any tips to save time/hassle? Is there a service manual available? Quote
iank99 Posted February 24, 2024 Report Posted February 24, 2024 @Hockeybod - if it's a late model Frog (which is very likely) then the procedure is essentially the same as the Jester i.e. open the case, swap the battery, close & secure the case. It's a CR2032 same as in the Jester - there are only two screws to remove, as you look side on to the desk - at the rear/back end of the side panel remove the lower crosshead screw at each end & the bottom tray will be free to 'hinge'. Be careful when lifting the front panel - there is an earth cable between the processor and front panel that is shorter than the ribbon cables. Points to remember... The bottom tray locates in a groove in the case extrusion at it's lower/front edge - it can be a faff sometimes to locate it back in. Put the battery in the right way round (yes - I know... it has happened!) When done, power up the desk - go in to Super User & do a Reset/Clear all so that the internal patch tables reset - job done! 1 Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
