Hi @phosphene
If there are cues programmed onto the Master Playback, you will need to get rid of these first. If you don't need them, tap DELETE, and then tap the Master Playback's GO button to delete the whole playback.
With the Master Playback empty, hold SETUP and tap the Master Playback's GO button. You can then choose "Grand Master" from the options on the touchscreen.
Please see the link below for more information...
https://www.zero88.com/manuals/zeros/cues-playbacks/special-playback-functions
I hope this helps.
Email Support
