phosphene Posted February 19 Report Posted February 19 A couple of years ago I set the master playback fader on local venue's FLX-S to be a master blackout. Someone has changed this (of course). Can anyone remind me how I did it? Quote
Edward Z88 Posted February 19 Report Posted February 19 Hi @phosphene If there are cues programmed onto the Master Playback, you will need to get rid of these first. If you don't need them, tap DELETE, and then tap the Master Playback's GO button to delete the whole playback. With the Master Playback empty, hold SETUP and tap the Master Playback's GO button. You can then choose "Grand Master" from the options on the touchscreen. Please see the link below for more information... https://www.zero88.com/manuals/zeros/cues-playbacks/special-playback-functions I hope this helps. Quote Edward Smith Product Specialist Email Support
phosphene Posted February 20 Author Report Posted February 20 Thanks as ever Edward. I'll try that tomorrow when I get access again. Hope you are well. All the best. Cliff 1 Quote
