Hi @fischchen
Welcome to the forum.
1 hour ago, fischchen said:
is it possible to patch a multi cell fixture like the EUROLITE LED TMH-H90 to different faders (one per cell) on the FLX s24?
You wouldn't be able to patch this fixture onto multiple channel faders. This is because the fixture contains "master" parameters, which affect/control both cells.
If the fixture did not have master parameters, and the parameters in the fixture belonged to one cell or the other, then you could patch the individual cells as separate fixtures.
You could however record the separate cells of the fixture into separate playbacks. You could therefore have a single playback that controls the intensity of the first cell, and a second playback that controls the intensity of the second cell for example.
Please let us know if you have any questions.
  • Thanks 1
