noteningenieur Posted February 11, 2024 Report Posted February 11, 2024 How is it possible to change the palette (colour) in a running playback (1 cue = submaster)? So far this is only possible in Chanel mode or when a group is selected. Thanks for helpful answers Martin Nehrig Quote
kgallen Posted February 11, 2024 Report Posted February 11, 2024 Change permanently or temporarily? I think your main options are to select the fixtures/group and then tap the palette so this is in the programmer (enable programmer time if you want this to fade). To keep this use UPDATE to change in the cue, or alternatively RECORD this into another playback and then use this LTP to override the colours in the running playback. Quote
