Trapdoor Posted February 7 Report Share Posted February 7 Is there a way that window assignments to the various desktop tabs can be saved? Running 7.14.2 It’s a bit frustrating after setting up say Colour Pallets on Monitor 2 and Effects on 3 (as an example) that on desk reboot they’re all unassigned again. Thanks. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 8 Report Share Posted February 8 Hi @Trapdoor 12 hours ago, Trapdoor said: Is there a way that window assignments to the various desktop tabs can be saved? Running 7.14.2 It’s a bit frustrating after setting up say Colour Pallets on Monitor 2 and Effects on 3 (as an example) that on desk reboot they’re all unassigned again. When you switch on the console, the custom desktop layouts that were present when the console was last used should be recalled. Please rearrange your desktop layouts how you'd like them. Then tap SETUP twice to enter and exit Setup, which will force the show file to be saved to the internal storage. If you then switch the console off and on again, are the custom desktop layouts recalled? Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Trapdoor Posted February 8 Author Report Share Posted February 8 @Edward Z88 Thanks for the information and I thought I was going a bit mad because that’s how I thought it worked and would have expected it to work. However I’ve just checked again and nope, it wouldn’t save the desktops and in fact after shuffling screens into desktops, when rebooted it loaded to a completely empty suite of Desktops, even Desktop 1. So I factory reset the desk and now it’s working as expected again. Fortunately we’ve only just started for the spring production so nothing lost that 20 mins of repatching won’t fix! Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 8 Report Share Posted February 8 13 minutes ago, Trapdoor said: So I factory reset the desk and now it’s working as expected again. Thanks very much for the update. Please keep an eye on this. If the issue happens again, this could suggest the console's internal battery is going flat. In which case, we can provide instructions on how to replace the battery. 1 Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
KWR88 Posted February 8 Report Share Posted February 8 That may indicate a possible battery issue if the screens are coming up blank Is it holding the date and time correctly? Do you see or have you have seen any NVR error message when you boot the desk up? 1 Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Trapdoor Posted February 8 Author Report Share Posted February 8 2 minutes ago, Edward Z88 said: Thanks very much for the update. Please keep an eye on this. If the issue happens again, this could suggest the console's internal battery is going flat. In which case, we can provide instructions on how to replace the battery. @Edward Z88 I hope it isn’t as I only changed it in January as a precaution 🤣 Quote Link to comment Share on other sites More sharing options...
Trapdoor Posted February 8 Author Report Share Posted February 8 Just now, KWR88 said: That may indicate a possible battery issue if the screens are coming up blank Is it holding the date and time correctly? Do you see or have you have seen any NVR error message when you boot the desk up? @KWR88 … yep, it’s holding its date and time OK and no error messages on booting the desk. It appears to be working as expected now, but will see once I load the fixtures back. 1 Quote Link to comment Share on other sites More sharing options...
Trapdoor Posted February 10 Author Report Share Posted February 10 Quick update … all seems to be working fine now and loads all the correct desktops on a reboot even with the fixtures and Playback/cue stack loaded. Must have got something corrupted internally 🤷🏼♂️🫤 2 Quote Link to comment Share on other sites More sharing options...
