thierry Posted January 25 Report Posted January 25 Hi everybody, I would like to know why the last step of a chase is not reacting like the other ones : I've created a chase with 4 Par Led and i wonder why, when the chase is running, the last step is not fading out before to loop to the first step ( crossfade is working well between steps 1, 2, 3) ? Quote
Edward Z88 Posted January 29 Report Posted January 29 Hi @thierry Apologies for the delayed response - I've been on holiday. On 1/25/2024 at 8:27 AM, thierry said: I've created a chase with 4 Par Led and i wonder why, when the chase is running, the last step is not fading out before to loop to the first step ( crossfade is working well between steps 1, 2, 3) ? Please could you email a copy of your show file to support@zero88.com? We can then investigate further. If a chase has a colour fade percentage, all steps of the chase should fade by this amount. The last step will fade back to the first using this percentage. Please let us know if you have any questions. Quote Edward Smith Product Specialist Email Support
thierry Posted January 31 Author Report Posted January 31 Hi Edward, On 1/29/2024 at 6:19 PM, Edward Z88 said: Apologies for the delayed response - I've been on holiday. We all need it, no problem at all. On 1/29/2024 at 6:19 PM, Edward Z88 said: If a chase has a colour fade percentage, all steps of the chase should fade by this amount. The last step will fade back to the first using this percentage. It's ok now, thank you. 1 Quote
