Hi @AlexTec
  On 1/17/2024 at 10:50 AM, AlexTec said:
Hello Edward. I use FLX S48. Moving Head Eurolite LED TMH S90  Eurolite LED TMH-S90 Moving-Head Spot – Musikhaus Thomann  is not in the Device-Library. I built it myself using the Fixture-tool, unfortunately it doesn`t work perfectly. can i get a Fifture file fromyour site?
Expand
Eurolite LED TMH-S90 fixture file:
Eurolite LED TMH-S90.iftFetching info...
  On 1/17/2024 at 11:14 AM, Davidmk said:
Requests for new fixtures should be made in this topic Fixture Support & profile requests. You need to include details of the fixture - ideally a link to or scan of the manual.
Expand
As @Davidmk mentions, please follow this guide if you find that the fixture you are trying to control is missing from your console's library...
https://www.zero88.com/manuals/zeros/patching/add-fixtures/missing-fixtures
Hope this helps.
The link provided by @Edward Z88 is the right one. The link I supplied gets you the latest library and the fixture editor but, unless I've  missed it, not the contact for getting new fixtures. Edward's takes you to the online manual and a link in that opens an email for requesting a new fixture.
@Edward Z88: Am I mistaken in thinking the forum topic used to go direct to fixture requests? (Or does it still but I failed to find it?)
Expand
The forum link used to go to the "Support" section of the ZerOS Library webpage. This no longer exists, so the link was just taking you to the ZerOS webpage.
I've therefore updated the forum link, to direct straight to the ZerOS manual...
https://www.zero88.com/forum/forum/149-fixture-support-profile-requests-⧉/
  • Thanks 1
