AlexTec Posted January 17, 2024 Report Posted January 17, 2024 Hello Edward. I use FLX S48. Moving Head Eurolite LED TMH S90 Eurolite LED TMH-S90 Moving-Head Spot – Musikhaus Thomann is not in the Device-Library. I built it myself using the Fixture-tool, unfortunately it doesn`t work perfectly. can i get a Fifture file fromyour site? King regards, Alex. Mail: stadthalletechnik@boppard.de
Davidmk Posted January 17, 2024 Report Posted January 17, 2024 Requests for new fixtures should be made in this topic Fixture Support & profile requests. You need to include details of the fixture - ideally a link to or scan of the manual. Daresay @Edward Z88 will see this and pick it up but I suspect the proper route is quicker. 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Edward Z88 Posted January 17, 2024 Report Posted January 17, 2024 Hi @AlexTec 30 minutes ago, AlexTec said: Hello Edward. I use FLX S48. Moving Head Eurolite LED TMH S90 Eurolite LED TMH-S90 Moving-Head Spot – Musikhaus Thomann is not in the Device-Library. I built it myself using the Fixture-tool, unfortunately it doesn`t work perfectly. can i get a Fifture file fromyour site? Eurolite LED TMH-S90 fixture file: Eurolite LED TMH-S90.ift 7 minutes ago, Davidmk said: Requests for new fixtures should be made in this topic Fixture Support & profile requests. You need to include details of the fixture - ideally a link to or scan of the manual. As @Davidmk mentions, please follow this guide if you find that the fixture you are trying to control is missing from your console's library... https://www.zero88.com/manuals/zeros/patching/add-fixtures/missing-fixtures Hope this helps. Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Davidmk Posted January 17, 2024 Report Posted January 17, 2024 The link provided by @Edward Z88 is the right one. The link I supplied gets you the latest library and the fixture editor but, unless I've missed it, not the contact for getting new fixtures. Edward's takes you to the online manual and a link in that opens an email for requesting a new fixture. @Edward Z88: Am I mistaken in thinking the forum topic used to go direct to fixture requests? (Or does it still but I failed to find it?) 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Edward Z88 Posted January 17, 2024 Report Posted January 17, 2024 11 minutes ago, Davidmk said: @Edward Z88: Am I mistaken in thinking the forum topic used to go direct to fixture requests? (Or does it still but I failed to find it?) The forum link used to go to the "Support" section of the ZerOS Library webpage. This no longer exists, so the link was just taking you to the ZerOS webpage. I've therefore updated the forum link, to direct straight to the ZerOS manual... https://www.zero88.com/forum/forum/149-fixture-support-profile-requests-⧉/ 1 Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
AlexTec Posted January 17, 2024 Author Report Posted January 17, 2024 Thanks for the quick reply. I'm sorry I misunderstood something here, now I know how to do it right. Kind regards AlexTec 2
