Bonjour, je rencontre un souci quand j'enregistre des mémoires dans le master playback, quand j'utilise les projecteurs halogènes j'ai bien les temps de monter et de descente, mais quand j'utilise simplement des projecteurs LED RVB je n'ai pas accès au temps de monter et de descente simplement de couleur est-ce normal ?
Merci
jmd
If your LED fixtures only have RGB DMX channels then you will need to map a different fixture definition that includes "virtual intensity".
Virtual Intensity is a feature that allows the console to scale the fixture's RGB channels proportionally to act as an overall intensity.
First, check if your fixture has its own in-built intensity or dimmer DMX channel and if so, swap to using a more suitable fixture definition.
  On 1/8/2024 at 4:36 PM, jmd said:
Sorry, I wanted to know if there was anything to do on the console?
Expand
If the patched fixture only has R, G, B colour "handles" then that is all you have to work with.
If you want an "intensity" channel then the fixture definition loaded for your LED projector has to tell the desk to create a "virtual intensity" and what real fixture channels to scale.
If your LED fixture is only R-G-B then the ZerOS library will already include an R-G-B-(VI) fixture definition which you could use.
Alternatively, if your fixture has other channels (strobe, program etc) then FLX now has an inbuild fixture definition tool you could use. I've never used it though, sorry. Maybe@Edward Z88 can advise.
https://www.zero88.com/manuals/zeros/patching/add-fixtures/fixture-creator
Edit: Having quickly watched the video, I'm not sure if virtual intensity channels can be created in the on-console fixture generator.
Expand
When creating a fixture in the ZerOS Fixture Editor, if a Virtual Intensity parameter is required, ZerOS will automatically create one to scale LED emitters.
  • Like 1
Ok, pourquoi les temps de monter et descente sont automatiques avec de l'halogène mais pas avec les led rgbwa ( seulement le temps de couleurs est disponible) ?
Merci
Si une mémoire contient uniquement des informations sur la couleur, où seules les valeurs de couleur changent lors de l'entrée dans la mémoire, vous ne verrez qu'un temps de fondu affiché pour la couleur. Vous ne verrez les temps de fondu affichés pour « Up » et « Down » que si le signal inclut des changements dans les valeurs d'intensité.
If a cue just contains colour information, where only colour values change when going into the cue, you will only see a fade time shown for colour. You will only see fade times shown for "Up" and "Down" if the cue includes changes in intensity values.
Halogen only has intensity. When you patch a "Dimmer" fixture that gives you an intensity control.
If you don't have up/down for your LED then either:
(1) Your LED doesn't have an intrinsic dimmer channel, or you patched the wrong definition
or
(2) The cue you programmed didn't have a change in intensity
If you respond to some of the points in my earlier comments, then we can narrow this down more. At the moment you've given me no more information to help you. I'm guessing what the problem is.
Bonjour, je reviens vers vous.
J'ai fait quelques essais hier soir concernant les temps de monter et descente.
Je rencontre le problème suivant avec des projecteurs led RVBGW
J'enregistre le 1er effet avec couleur dans Master playback a 100% j'ai bien faders UP et fade down sont enregistrés
Effet 2 je baisse et remonte à 100% avec couleurs les mêmes faders et fade UP et fade down n'apparaissent plus.
La même chose pour les effets suivants.
Je ne comprends pas 🙏
Merci
@jmd Can you attach your showfile please, then @Edward Z88 can take a look (save to USB stick then on PC drag and drop into a new comment).
Expand
Can you explain this again please. Is this one cue that drops intensity to 0% and then a following cue that increases intensity to 100%?
Oui, avec le même fader j'enregistre une couleur de 0 a 100% effet un
Je baisse le même fader,
Je remonte à 100 % et je n'ai plus Fade UP et fade down
  On 1/9/2024 at 9:45 AM, jmd said:
Yes, with the same fader I record a color from 0 to 100% effect one
I lower the same fader,
I go back to 100% and I no longer have Fade UP and fade down
Expand
If I understand you correctly, the 0% and 100% need to be two separate cues.
Cue 1:
I record the 1st effect with color in Master playback at 100% I have faders UP and fade down are recorded
Expand
Cue 2:
Effect 2 I lower and raise to 100% with colors the same faders
Expand
Cue 3:
Expand
