showguy Posted December 28, 2023 Report Share Posted December 28, 2023 Hello, Is there any possibility to control single channels from the ZerOS Remote App? From reading online I can tell the Apple Watch App supports this, however the app on my android doesn't appear to. Am I missing something? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 29, 2023 Report Share Posted December 29, 2023 Hi @showguy To control the intensities of individual fixtures with the ZerOS Remote app, you can use syntax commands. The default screen of the app is a number-pad where you can type these commands. Please see the link below for information on syntax commands… https://www.zero88.com/manuals/zeros/selection-and-intensity/commands Alternatively, if you wanted to use onscreen faders to control intensities, you could use the ZerOS Monitor app instead, and view the Faders desktop. The Faders window can then be put into Fader Level mode. See the link below for more information… https://www.zero88.com/manuals/zeros/setup/settings/operational#mff I hope this helps. Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
showguy Posted January 2 Author Report Share Posted January 2 On 12/29/2023 at 12:59 PM, Edward Z88 said: Hi @showguy To control the intensities of individual fixtures with the ZerOS Remote app, you can use syntax commands. The default screen of the app is a number-pad where you can type these commands. Please see the link below for information on syntax commands… https://www.zero88.com/manuals/zeros/selection-and-intensity/commands Alternatively, if you wanted to use onscreen faders to control intensities, you could use the ZerOS Monitor app instead, and view the Faders desktop. The Faders window can then be put into Fader Level mode. See the link below for more information… https://www.zero88.com/manuals/zeros/setup/settings/operational#mff I hope this helps. Thanks for the reply, this should do it. 1 Quote Link to comment Share on other sites More sharing options...
