Okay I encoutered a weird problem during show today...
When I put up channel fader 25 the value changes to FF as expected; but... the value of channel 26 goes up to 18% as well :S At first I thougt it was a problem with our dimmers, but the desk output screen tells me the desk is sending out wrong information. I've tried rebooting etc, that won't help... I guess something is broken, and this isn't really a bug; but what could it be that causes this problem?
I've also solved it; by raising fader 26 just a little bit the value of that one stays at -- while raising 25. But still the faders aren't working the way they're supposed to be. Should I check the desk in for a maintanance session? :(
It sounds like fader 26 may have a fault or be "dirty".
It would be worth giving a small drop of switch cleaner to see if this cures the problem.
Regards,
Keith Rogers
I have the same problem with subfaders...
If i move them slow the current channels flash.
Sometimes other channels flash to... f.eks channels on the neares subfader ...
TrondW
