Hi All,
This question may have been asked before but I'm having problems with Chase Speed. I don't want the chase to be activated in BPM. I want it to Chase using the Fade Times I have set in the Cue List. I'm sure I read somewhere that if you set the BPM to "0" then the Chase will ignore the BPM and use the fade times. But when I enter "0" in the BPM button as soon as I hit "Enter" it reverts to "1" and if you select "Global BPM" and try and wind the Encoder wheel to "0" it stops at "1". Am I missing something here. Has this feature been removed with the latest update. I am running the latest version and it was the same in the previous version.
Dave
Hi @simzee47
This functionality was removed several versions ago. Chases will ignore all cue fade, delay, and auto timings set in a playback.
To use the cue timings rather than BPM, you will need to revert the playback from a chase, and then add "Auto After" triggers to each cue in the playback. Please see the link below for more information...
https://www.zero88.com/manuals/zeros/cues-playbacks/cue-settings/cue-triggers
The playback will then run through the cue timings and loop automatically.
Please let me know if you have any questions.
Hi Edward,
Thanks for reply. I had half worked out that this was what I woulld have to do. I have 4 scrollers and I just wanted them to move 1 colour every few minutes just as a colour changing background to a social evening at the Theatre. I'll experiment.
Dave
  • Like 1
