Techie_v2 Posted December 12, 2023 Report Posted December 12, 2023 Hi all, Can someone remind me why the pause button is flashing after recording a cue. I can figure it out! Thanks Quote
kgallen Posted December 12, 2023 Report Posted December 12, 2023 I can't remember if this one is a long standing buggette, or whether it means what's on stage versus in the cue is out of sync and you need to GO to align them! Yea ok, useless answer! I found this in an old Beta comment, if it applies to your scenario: On 9/23/2017 at 11:34 PM, kgallen said: Also when I do Shift+Go (Go Snap) why does the Pause/Back button start flashing? Shift+GO also acts as a pause - stopping chases or Auto cues from triggering (useful when updating cues) and hence the Pause button flashes to let you know. Quote
Techie_v2 Posted December 12, 2023 Author Report Posted December 12, 2023 Hmmm, but this is just after pressing Record -> master playback button Using tracking made if that helps? Quote
Edward Z88 Posted December 12, 2023 Report Posted December 12, 2023 3 hours ago, Techie_v2 said: Can someone remind me why the pause button is flashing after recording a cue. If you have SmartTag disabled, and you record a cue, you will immediately snap into the cue you just recorded, and the manually adjusted programmer values will be cleared automatically. As you have essentially done a GO Snap without running the cue's fade times, the Pause button will flash. Hope this helps. Quote Edward Smith Product Specialist Email Support
Techie_v2 Posted December 13, 2023 Author Report Posted December 13, 2023 Thanks Edward, I haven't checked that smarttag was disabled, will do tomorrow. It's something I always forget to turn back on after disabling to stop an effect etc. Wish there was a way to have it auto re-enable after turning it off as 99% of the time I want it on, but forget when recording the next cue Quote
Edward Z88 Posted December 13, 2023 Report Posted December 13, 2023 39 minutes ago, Techie_v2 said: Wish there was a way to have it auto re-enable after turning it off as 99% of the time I want it on, but forget when recording the next cue I definitely understand this request. On the other hand, personally I would not want SmartTag to turn back on if I'd turned it off. More thought required... Quote Edward Smith Product Specialist Email Support
Jon Hole Posted December 13, 2023 Report Posted December 13, 2023 1 hour ago, Edward Z88 said: More thought required... SHIFT+RECORD is a one-off SnapShot. I wonder if this functionality could be customised? Quote Jon Hole Global Product Manager, Systems and Control
Techie_v2 Posted December 13, 2023 Author Report Posted December 13, 2023 40 minutes ago, Jon Hole said: SHIFT+RECORD is a one-off SnapShot. I wonder if this functionality could be customised? Hi Jon, Yeah I suppose that would work as long as the following cue after the snapshot one doesn't require any move on dark features to have run? Quote
Jon Hole Posted December 14, 2023 Report Posted December 14, 2023 I was more "thinking aloud" about a potential new feature (in a future software update) that allows you to customise the functionality of SHIFT+RECORD Quote Jon Hole Global Product Manager, Systems and Control
Techie_v2 Posted December 14, 2023 Author Report Posted December 14, 2023 Ahh right, But yes, having programed and done another show tonight I did have smart tag disabled Quote
