BjDick Posted December 8, 2023 Report Share Posted December 8, 2023 Another silly question from a newbie: Let's assume I have a playback which includes some dimmer channels only. It's straightforward to make the GO button enable those fixtures as long as being pressed ("Flash"). But can I make the playback to fade out the dimmer channels when I release the GO button? This seems to be easy when I enable the playback with the fader. However, when enabling it with the GO button (configured as "Flash") the dimmers seem to switch off instead of fade away. BTW: Is there a more detailed manual for ZerOS as that shipped for FLX S24? (so that I can look those things up in the manual instead of spaming the forum ;-)) Best & Thanks a lot! Björn 1 Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted December 8, 2023 Report Share Posted December 8, 2023 2 minutes ago, BjDick said: can I make the playback to fade out the dimmer channels when I release the GO button? Currently, there's no native way to do this via a flash button. It has been requested before and is logged (reference ZOS-3202) - I've added your comment as an additional request. If you only want to flash (not press-and-hold), you could create two cues - first one snaps on, second one fades out, and then set the second cue to Auto follow. Now, pressing the GO button will snap the light on, then fade it back out. You will need the physical fader to be at full to make this work. 2 minutes ago, BjDick said: BTW: Is there a more detailed manual for ZerOS as that shipped for FLX S24? (so that I can look those things up in the manual instead of spaming the forum ;-)) Yes, our online manual is here: https://www.zero88.com/manuals/zeros?filter=1 Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
iank99 Posted December 9, 2023 Report Share Posted December 9, 2023 20 hours ago, BjDick said: Another silly question from a newbie: Let's assume I have a playback which includes some dimmer channels only. It's straightforward to make the GO button enable those fixtures as long as being pressed ("Flash"). But can I make the playback to fade out the dimmer channels when I release the GO button? This seems to be easy when I enable the playback with the fader. However, when enabling it with the GO button (configured as "Flash") the dimmers seem to switch off instead of fade away. That used to be one of the nice features of chases on Sirius (and I think Lightmaster) being able to modify both sides of the steps on a chase - it was also a feature in GeniusPro Strand desks (you could set it on effects, memories & flash buttons) and was very handy for lightning effects or for snapping a solo spot in then letting it fade gently out (sometimes a snap out feels too harsh). Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 9, 2023 Report Share Posted December 9, 2023 4 hours ago, iank99 said: That used to be one of the nice features of chases on Sirius (and I think Lightmaster) being able to modify both sides of the steps on a chase Intensity transitions between the steps of a chase can also be configured in ZerOS. See here for more information… https://www.zero88.com/manuals/zeros/cues-playbacks/chases/chase-settings#intensity 1 Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
