Neil.Roehrborn Posted August 22, 2004 Report Posted August 22, 2004 I would like to find a better way to edit submaster times. What I am doing now is using the arrow keys to move through the submaster menu. It seems clumsy and time consuming (many button pushes) to arrow down and then arrow back up to get out of the edit menu after the changes have been made. It's not a bad task for one submaster, but if you want to change the times on a whole page of subs it gets tedious. Is there a quicker way to change these times I don't know about? Quote
K-Nine Posted August 23, 2004 Report Posted August 23, 2004 Because of the way the user interface was originally designed around the main LCD on the front panel, it is only possible to edit the times for one submaster at a time. However, here are a couple of tips that may help speed up the process. When the cursor is in one of the fade time fields - pressing the SUBMASTER button will move the cursor straight back to the submaster number field. When the cursor is in the submaster number field - a quick way to select the required submaster to edit is to use the Page Up/Down keys and submaster flash button on the front panel. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
