Search the Community
Showing results for tags 's 24'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
  • Product Support
    • FLX
    • FLX S24 & FLX S48
    • Data
    • Power
    • Legacy Products
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Found 1 result
  1. Hello Folks, I'm not sure if this is a software fault or an operator fault, but I was hoping for a quick setup of the new FLX s 24 for a client but it turned into a long days work! For some reason, some of the LED fixtures were flickering (strobing in white) when connected to DMX. I thought at first this may have been a cable or fixture issue but having tried numerous combinations there was still an issue. So, I went into the menu to check settings and I disabled RigSync, miraculously it solved the issue straight away! As this was a quick setup I didn't have time to look into if there may have been any other configurations that could have caused it, but I thought I would check here to see if it was a software fault or that of myself. Thanks in advance.
