Search the Community
Showing results for tags 'long fade'.
Hi, I'm using a Fat Frog with 10.12. I've been having a play with Tracking [Mode=Partial, Tracking=On(--), Brightness=Channel] using two generics for a starter, before I complicate things by adding some fixtures. (I'm hoping to take the plunge and use tracking in our next show). I have successfully managed to track a chase initiated in an earlier cue, through later cues where the chasing channel is not tagged but other channels are tagged and are moving about. The chase keeps running until a later cue when the channels used by the chase are tagged (as a scene) and revert to a static state. All good. However I have been unable to track a long (scene) fade on one channel through subsequent (scene) cues that don't have that channel tagged, where I would expect it to track. (In this example, all memories are of type scene). CUE9 Ch1=FF, Ch2=00, time=3s/3s CUE10 Ch1=00, Ch2=00, time=3s/30s [initiate long fade down on Ch1.] CUE11 Ch1=TR, Ch2=FF, time=3s/3s [Ch1 is tracking (not tagged in this memory). I expect Ch1 to continue on 30s down fade and Ch2 to fade up in 3s] I GO on CUE9 and Ch1 fades up to FF in 3s, Ch2 is 00. I GO on CUE10 and Ch1 begins its 30s slow down fade. Ch2 stays at 00. All as expected. Before CUE10 has completed its 30s down fade (say 10s into the fade), I GO on CUE11. Ch2 fades up in 3s as expected. However Ch1 now fades out in the 3s down time of CUE11, even though it is tracking (not tagged) in CUE11. I would have expected Ch1 to continue on its 30s down fade. Ch1 is tracking in CUE11 so I would not expect CUE11's down fade time of 3s to affect Ch1. In each cue (memory), I can confirm using Preview that Ch1 and Ch2 are either tagged [grey] in that cue or tracking [magenta] as expected, so I'm happy that the tagging is correctly set for each channel in each memory (cue). However I see CUE11 stomp over Ch1's CUE10 fade time for tracked Ch1 as described above. Am I doing something wrong, or is this not supported or is this a bug? Thanks, Kevin
