Search the Community
Showing results for tags 'fat frog'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
  • Product Support
    • FLX
    • FLX S24 & FLX S48
    • Data
    • Power
    • Legacy Products
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Found 7 results
  1. Hi, I'm using a Fat Frog with 10.12. I've been having a play with Tracking [Mode=Partial, Tracking=On(--), Brightness=Channel] using two generics for a starter, before I complicate things by adding some fixtures. (I'm hoping to take the plunge and use tracking in our next show). I have successfully managed to track a chase initiated in an earlier cue, through later cues where the chasing channel is not tagged but other channels are tagged and are moving about. The chase keeps running until a later cue when the channels used by the chase are tagged (as a scene) and revert to a static state. All good. However I have been unable to track a long (scene) fade on one channel through subsequent (scene) cues that don't have that channel tagged, where I would expect it to track. (In this example, all memories are of type scene). CUE9 Ch1=FF, Ch2=00, time=3s/3s CUE10 Ch1=00, Ch2=00, time=3s/30s [initiate long fade down on Ch1.] CUE11 Ch1=TR, Ch2=FF, time=3s/3s [Ch1 is tracking (not tagged in this memory). I expect Ch1 to continue on 30s down fade and Ch2 to fade up in 3s] I GO on CUE9 and Ch1 fades up to FF in 3s, Ch2 is 00. I GO on CUE10 and Ch1 begins its 30s slow down fade. Ch2 stays at 00. All as expected. Before CUE10 has completed its 30s down fade (say 10s into the fade), I GO on CUE11. Ch2 fades up in 3s as expected. However Ch1 now fades out in the 3s down time of CUE11, even though it is tracking (not tagged) in CUE11. I would have expected Ch1 to continue on its 30s down fade. Ch1 is tracking in CUE11 so I would not expect CUE11's down fade time of 3s to affect Ch1. In each cue (memory), I can confirm using Preview that Ch1 and Ch2 are either tagged [grey] in that cue or tracking [magenta] as expected, so I'm happy that the tagging is correctly set for each channel in each memory (cue). However I see CUE11 stomp over Ch1's CUE10 fade time for tracked Ch1 as described above. Am I doing something wrong, or is this not supported or is this a bug? Thanks, Kevin
  2. We have a Fat Frog board and are having a hard time saving memories to disk. All memories are setup as scenes and when the memories are saved, everything in the library is saved to the disk. Everything seems to be considered one show. What am I overlooking? Thanks so much, I appreciate any help!
  3. Hi there, I hope I'm posting this in the right place. It's my first time on here. I run the lights at my college for the various events that go on throughout the year. We recently obtained two lovely ledj performer 36 rgb LED lights. Only problem is there isn't a pre-made personality in the library provided by Zero 88, and I've had a go at writing my own but it didn't work. If anyone has a personality for this light that works with a fat frog desk, or is able to give me a hand with creating one that would be very much appreciated. Many thanks Sam
  4. Hey, I have a Fat Frog at the venue my latest show is in. It's largely running fine, however it loses nearly all of it's settings every time we power cycle it. I haven't tested it excessively due to time restraints, but I know it forgets memories 90% of the time, time and date, and lock code, although patch settings are fine. I have been saving the show to floppy and reloading it any time the desk gets rebooted, so it's not the end of the world, but I'd really like to avoid losing the entire show immediately after a late night lighting plot again... Is there an internal battery that needs to be replaced perhaps? Thanks Sam Mence Creative Ambiance Stage Technologies NZ
  5. Hey, trying to organise a custom fixture for the old Fat Frog to run some LEDs; Where might I find a download for the fixture editor software? Thanks Sam Mence Creative Ambiance Stage Technologies NZ
  6. Hey all! Well it's life with us has come to the end, the desk is too small for us! It's been to small for the past year/2 but it was not in the budget to get another one so we expanded to PC software as a temp solution, sadly it's not the same as programming on a desk. So we hope to get the new Solution Series Console to replace it in time for a charity panto we have coming up. Does anyone know any places apart from eBay where we could sell the desk? Or do you know anyone who's after one? The desk was brought brand new in nov 07, it's in amazing condition. not a dent, scratch or mark on it apart from a few scuffs on the bottom and the protective coating over the LCD screen has come off, only about 1cm2. Cleaned regularly & PAT tested yearly. We look after out equipment. Cheers All
  7. Hi Sorry, they may be a topic on this already but I am new to this forum. I have a Fat Frog desk where I work at my local high school. Every time I use the Floppy Drive the desk restarts, after it has restarted a couple of times it will then work and I can load/save shows etc. It takes twice as long to load shows as I have to wait for it to boot up every time I load from a floppy. I have tried replacing the drive which didn't help. It is especially bad when I try and load a fixture from a floppy disk. Our main school show is coming up next week and although the board saves shows to its memory, I like to have a backup but I am concerned that all the restarting isn't doing the desk any good. Thanks Jack
