Search the Community
Showing results for tags 'during show'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
  • Product Support
    • FLX
    • FLX S24 & FLX S48
    • Data
    • Power
    • Legacy Products
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Found 1 result
  1. Hello all. I'm relatively new to a Jester 24/48, using it for a small amdram group to control up to 18 channels of conventional lamps through 3 betapak 3 dmx controlled dimmer packs (no problems) and many LED lamps. 14 of the LEDs use 6 dmx channels each and we have 3 chauvet battens which can use up to 17 dmx channels each. For some shows, I've managed to group the lamps and patch the dmx addresses so that one fader operates several dmx addresses and therefore lamps, but I'm struggling to get anything more complicated than that. The Jester Manual tells me that "The DMX patch may be changed at any time without affecting the memory data stored in the desk." So, when programming a show, I have tried re-patching the dmx addresses part way through a programme so that the faders control different aspects of different lamps at different times in the programme / show. But it doesn't work / remember the various states, so I wonder what I'm doing wrong. If I record Scenes 1 to 10 with one set of dmx patching, then change it all for scenes 11 to 20, then go back to scene 1 the new dmx addresses are there, not the ones I set for scene 1. I must admit I've only tried it on Phantom Jester so far to test it out and start a new show at home, but should this work? Many thanks in advance. jimbo
