Search the Community
Showing results for tags 'arri skypanel'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
  • Product Support
    • FLX
    • FLX S24 & FLX S48
    • Data
    • Power
    • Legacy Products
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Found 1 result
  1. Hi, I wonder if anyone can help. I have 12 ARRI Skypanels networked using ethernet through a couple of small switches (they are on two hanging trusses) and plugged directly into the FLX console ethercon port. Skypanels are set up for Artnet on 10.x.x.x with 255.0.0.0 gateway, DMX channels assigned correctly (12 channels per Skypanel). When I unplug the console and plug in a laptop running LightJams, all of the fixtures are detected and I can assign everything and control. However for the life of me I can't get it working with FLX. Artnet is set up on 10, and all the fixtures are added with correct channel assignments. Has anyone set up FLX using Artnet over a ip only network? Hoping someone has some wisdom to share. Thanks, Richard
