I'd like some advice on programming a Jester ML48, which I have some experience of, but only for one week per year, and this time I need to do something a little different.
The Jester will be running 48 channels of conventional dimmers, some Colorado LED Pars, and a couple of Martin Mac250s. The show is a musical and will be programmed using a standard cue stack for easy playback, which will handle all the LED colour changes and Mac movements. So far, no problem, as we've done all this before.
However, we will also be adding 12 Pulsar ChromaStrips on a ChromaZone controller, which we have never used before. I can see that we can set each ChromaStrip as a separate fixture on the desk, and can therefore change all or some of their colours, from one cue to the next, but is there a way of programming a colour fade that 'sweeps' across the fixtures from one cue to the next?
In other words, if all the ChromaStrips all blue in cue 27 and we want them to be red in cue 28, is there an easy way of programming a fade so that, on GO cue 28, Strip no 1 changes to red first, then strip 2, then strip 3, etc, until steady state is reached for cue 28 when they are all red? This should of course happen at the same time and over the same duration that all the other lanterns are changing their states for cue 28 too.
Any ideas would be gratefully received.
Many thanks, DickM
