When I try to live edit a memory, fade up the sub master fader. For example add one more peset channel into this memory. Fade up the preset fader, press record button and click merge. Then press clear button. Now if you fade down the preset, the preset fade will grab the output. Is there any way, after merge the memory and press the clear will release the preset fader.
