Search the Community
Showing results for tags 'CROSS FADER'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
  • Product Support
    • FLX
    • FLX S24 & FLX S48
    • Data
    • Power
    • Legacy Products
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Found 1 result
  1. Is it possible to add to 'time of fade in' or' time of fade out' a 'delay time' tu run a crossfading of 2 memories? (In theater, this time fonction is very necessary to late time out / time in, to have a soft crossfading). If a Channel remain @ the same % between 2 sequentials memories, does the % of channel don't change on stage during the crossfading? Is there any way to make a hand cross fading, separate up and down in RUN mode(except using SubMasters Faders) Already i use Software PC for main light board with a merging JESTER 24/48 HTP and I hesite to buy a JESTER TL in main LightBoard with the 24/48 in DMX in, as a control fading of Sub masters; I would appreciate the EDIT fonction, which allow, in RUN mode(during Reheasal or show) to modify some % of a Scene without disturbing the artists. I Use Zero 88 consoles since nos more than 20 Years and i appreciate the simplicity and thesolidity
