Search the Community
Showing results for tags 'Alphapack 2'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
  • Product Support
    • FLX
    • FLX S24 & FLX S48
    • Data
    • Power
    • Legacy Products
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Found 1 result
  1. Hi, I "manage" the hire section of a student run theatre. One of our alphapack 2s is having problems - based on the following symptoms, can anyone suggest anything? 1) On power on, the 'mid-dim buzz' - the sound you get normally mid fade - starts straight away, but very quickly becomes stuttery and broken up. 2) The moment any fader on the front is pushed up, the overload light starts flashing 3) Overload light goes solid at about 40% of any channel Note that this happens with nothing plugged into the outputs (even the fuses removed). If something is plugged in, it stays very dimmer and flickers. Any suggestions would be appreciated! Regards, Rich Hall
