Tim Olson
Everything posted by Tim Olson
  1. so in other words, I can record one parameter in a memory, and set the sub to play back just that parameter, but the only option I have is to play it with the timing in the memory or with no timing at all. I thought I read that if you put no timing in the memory, the sub would execute manually. apparently this is only for HTP levels. This means you can get either a faded or a snap exectution of the parameter - yes? I'm still in the dark about how to tag just one parameter peace, Tim
  2. how do you tag individual parameters? where in the setup menu can you separate things? thanks, Tim Olson AV Concepts
  3. what do you mean? I have been getting ltp parameters out of my subs....there's an ltp trigger level..... do you mean it's impossible to record just one parameter on a sub? didn't I just read that there's a way to output just the color, or beam, or position info to a memory? peace, Tim Olson AV Concepts
  4. Tim Olson
    Tagging
    I'm just about through with my first lil corporate show using the fat frog. I'm still confused about how tagging works - sometimes I'll notice the fixtures get tagged after running a sub up; sometimes the fixtures un-tag after I store a cue and I don't know if they recorded till I attempt playback; sometimes I record a cue and only one or 2 of the parameters record, not everything also - in Memories creen, what does F and S stand for in the CBP columns/ thanks, Tim Olson AV Concepts
