TylerHolpin
4,228 profile views
TylerHolpin's Achievements
  1. Hello, Hopefully you have had chance to check what Edward suggested for your to do. Regarding the software version, we would highly recommend updating to 7.9.3 which was released in the later parts of 2017. You can download it from the downloads tab at the top of the forum. Many thanks, Tyler
  2. Hi, Tyler here - I look after the Asian countries for Zero88. If you can email me direct on tylerholpin@eaton.com we will see what we can do. I have a very strong distributor in Japan that I can introduce you too. Thanks Tyler
  3. Hi Nick, Apologies for the slight delay in getting you this fixture. Please see the attached file. You can load this into your console via the USB port. If you need anything else, please don't hesitate to contact us. Thanks Tyler QTXLight - LUX-LD01 Spot 13Ch & 5Ch.ift
  4. Hello Duevelshoak, Our apologies for the delay in getting this profile to you. please see attached fixture profile with both 13 and 15 channel modes included. If you require anything else please do not hesitate to contact us again. Thanks, Eurolite LED TMH-X12 13 & 15 Channel.ift
  5. Hi Emrys, Please see attached the fixture profile for the Hurricane 1800. if you have any questions please do not hesitate to ask. Thanks, Chauvet Hurricane 1800.ift
  6. Hi JTorsson, Thank you for posting the fixture file here in the forum. Apologies for not getting around to the 2nd version of the file quick enough yesterday. Just let us know if you need anything else. Thanks, Tyler
  7. Hi JTorsson, File below for the Light Sky 1810 Beam Standard mode only currently - 16 channel. Please let me know if you need any of the other profiles made. Thanks, Tyler LightSky 1810 Beam FX - Standard 16Ch.ift
  8. TylerHolpin
    FLX "presets"
    Hello Lufferov, Once you have set up the look you want, and pressed "Record", before you chose the location you want to record to if you look on the "Record Window" you will see an option to record just Tagged parameters (which separates out the parameters to only record the one relevant to that attribute) or you can select "All Parameters". By selecting "All Parameters" you will see once the pallet is recorded that you have "ICBPE" in the pallet. This means that "Intensity", "Color", "Beamshape", "Position", and "Effect" have all been recorded in the same pallet. Hope this answers your questions, Thanks,
  9. Hi JB97 I Presume you mean they are not working whilst you are in "Run" mode on the console? What did you record onto the Submasters? Could you send through your show file and a little more explanation of what isn't working please? Thanks, Tyler
  10. Hello Youri, Thanks for your post. I will log your "move" request with Jon when he returns to the office and ask for his comments to be added to this thread. The "Update" and then pressing the touch screen is a valid command in our latest version of software 7.9. for ORB XF. 7.9 is available on our website and applies to FLX, ORB XF and SCD Server Pro. We are continuing to point uses of ORB XF & SCD Server Pro towards 7.8.2.36 currently with a note that they can choose to use 7.9 if they wish. If you want to give this software a try please go to - http://zero88.com/support/index.php?/Knowledgebase/Article/View/587/ Please let me know if there is anything else I can do. Many thanks,
  11. Hi Dan - Sorry for the time taken to reply to this question via the forum. So it sounds like all the fixtures have been selected at some point before applying an effect to just some of them (Just spokes or Pix Track.) Please ensure when recording these submasters that you have only selected the lights you want to use and nothing else is in the programmer. Also can you confirm that you are running version 7.8.2.36? If your not - please download it from - http://zero88.com/support/index.php?/Knowledgebase/Article/View/366/156/ Finally - if you still struggle with this then feel free to send me your show file and I can take a deeper look into what has been recorded. Thanks, Tyler
  12. Hi Deeeg, Are you able to plug in an external monitor via the VGA port and give us a screen shot of what is showing please? Thanks, Tyler
  13. Hi Daniel, Attached are the 3 profiles needed with all modes also, Let me know if there is anything else you need Thanks, Tyler Chauvet SlimPAR Hex & USB - 04.05.16.ift
  14. Hi James, I run the Solution training days in the Cwmbran factory, We aim to start the training at 10am, so ask you to arrive at 9:45 and should finish around 3pm. The Septebmer 22nd training is fully booked now, will get the website updated late this week. I have spaces left on 24th November if that suits you? Please email me for any further information or to book a place on the Solution training. tylerholpin@eaton.com Many thanks, Tyler International Sales - Zero 88
  15. Hello, If you send the fixture profile to myself on email I will take a look at it and create the Macro's in the fixture for you. email - tylerholpin@eaton.com Many thanks, Tyler International Sales - Zero 88
