agedo
Everything posted by agedo
  1. Hello! Have you found what some causes of freezing remote file errors which I sent to you? What should I do? Console does not turn the first time, to have to overload it 4-5 times!
  2. Thank you!
  3. Hello Jon! I need to eliminate a problem with continuous freezing of the panel, the last insertion led to threat of failure of performances, wanted to return previous 7.6.0, but at us didn't remain and at you on a site didn't find! How to correct it programmatically, or it is malfunction of iron and not to do without the address to dealers?
  4. Files I sent.
  5. Hi Franck After flashing the 7.7 console began to behave unpredictably, downloaded shows and startup submaster console freezes showing a black screen. The mistake file with .zdb expansion can't be attached to the letter how I can send it?
  6. Hi Franck Software version 7.7.0, serial number 0086101 11220125. It did not apply to distributors!
  7. Hello! I live in Russia, I work at theater and we have a Leap Frog 48 panel, insertions is changed regularly, but the panel all the same hangs, what you will advise? Thanks! debug_20-9-2013_15-37-37.dat
