cycy
Everything posted by cycy
  1. how can i change 1-48 faders flash button modes.its change after update to 7.8.now i can use just for on/off.need to change to flash. thank you.
  2. hi i need for Cyberlight CX model fixture. https://www.highend.com/pdfs/products/cyberlightturbo/cybercx.PDF *Standard / Enhanced Control 1 Pan Coarse 2 Pan Fine 3 Tilt Coarse 4 Tilt Fine 5 Color Wheel 6 Cyan 7 Magenta 8 Yellow 9 Static Litho 10 Rotate 11 Litho Rotate 12 Zoom 13 Focus 14 Iris 15 Effects Wheel 16 Frost 17 Shutter 18 Dim 19 Motor Speed 20 Control
  3. thank you i will try it.
  4. hi.i did it by myself but made a mistake and cant find where.maybe u can help me... genius motorshow 575 fixture.
  5. solution.
  6. or i need fixture for " genius motorshow 575 "
  7. Zero 88 Fixture Library - Release 24 . cant find the download link for this update.or can't find a page to download fixtures.thanks for help.
  8. here is 3 led ligth which i need.thank you for help. Ssp Yg-Led323XW CARNI/TZ 1 - MASTER DIMMER 2- RED 3 - GREEN 4 - BLUE 5 - WHITE 6 - COLOR MACRO 7 - STROBE 8 - AUTO 9 - AUTO SPEED ADJUSTMENT 10-DIMMER SPEED 11-ID ADRESS 12-BLOCK SELECTION Ssp Yg - Led 312w 1- MASTER DIMMER 2- RED 3- GREEN 4- BLUE 5- WHITE 6- COLOR MACRO 7- STROBE 8- AUTO 9- ID ADRESS IP LED PRO 354 1- GENERAL DIMMER 2- RED 3- GREEN 4- BLUE 5- WHITE 6- STROBE 7- SPEED FROM SLOW TO FAST 8- 0-50 CH1-CH6 0N 51-100 COLOR CHOSOSING PROCESS 102-150 GRADUAL CHANGE PROCESS 151-200 PULSE CHANGE PROCESS 201-250 CHANGE PROCESS 251-255 SOUND ACTIVATION
  9. Hi.my new solution desk is at work.but i need fixture for this produckts.thank you.. Ssp Yg - Led 312w Led Bolck 96w Ssp Yg-Led323 Xw 512dmx
