SimonH
4
Everything posted by SimonH
Hi Kevin, All working thank you. Even sorted my chases not triggering. I can only assume the raise lower were disabled as I had imported the show from a solution. Cheers, Simon
Ok thanks for that, will have a try next time I'm in. Cheers Simon
trying to get my head around the flx and not succeeding! I want to be able to record a scene onto one playback and a different scene onto another and be able to crossfade between them. Once I have recorded the scenes raising the fader does nothing until I press the button under it and it then snaps to the state. When I drop the fader it doesn't release the cue and so the colours are captured. The next fader does the same thing except it has no effect on the colours until I release the first playback and then that won't work. Can you tell me what might be wrong as this has to be possible otherwise the desk is a bit useless to a lot of our companies.
Hi Jon I have created a simple chase as per the instuctions and put the trigger and release on cues in the main stack. The chase works when triggered on playback 1 but not when running the main cue stack. File attached. Simon simple chase.isf
I have started a new topic so it doesn't get lost in the pinned one. Can we have a date please for the release of the user manual that will actually refer to all the new elements with the new software? It is a lovely desk and I am enjoying using it but at the moment I wouldn't recommend people buying it as there is so little in the way of reference material to actually work out how to use it. You wouldn't except this when buying a new TV.
ok, so I have loaded your file Alan and it seems to be working in the way I expected although not the way I wanted as each playback pulls down the level of the previous one. If you have 2 faders at 60% say and bring one of them down, the colour remains fixed so it doesn't leave the single playback active. There sems to be an issue with the way I am plotting the playbacks as the ones in your file operate straight away whereas mine need the flash button to load them which is what is grabbing the colour. If I clear that playback I get control of yours again but not mine until I press the flash button again. So I'm back to my original question - 'What am I doing wrong?' I've attached the file with both types of playback recorded. Thanks Minack default v3.isf
Hi, All I did with the 3 PB's was start with a clear plot and select all the LED's via a group. I put the intensities at 100 as nothing seem to be stored if I didn't. So the first PB was with all LED's in red. I then pressed 'clear' twice and repeated the process with blue and green. When trying to play back the colour remained as the last selected even after pressing 'shift clear' This is all being done with primaries at the moment but I can't how it will be different if I plotted a day state and a night state on 2 separate playbacks. What I'm really trying to achieve is what was possible on the Solution as submasters before it went wrong!!
Hi Jon, file attached as requested. I'm sure it's something simple I'm doing wrong! Cheers, Simon rgb subs.isf
I'm running 15 RGBW pars and if I plot a state in cue stack 1 that has all in blue and then a state in stack 2 that all are red, the cue stacks don't recall the colour. If I select them and change colour so say green and then clear everything, the cue stacks just bring them up as green. Why is the colour not being recalled with the cue stack?
Hi, Thanks do much for the reply works perfectly. Been away for a few weeks hence the slow reply!
is blind only available in the current output playback? If available on others how do you load it into blind?
any ideas on this?
Great thanks Jon. Will get myself one of those so I'm ready for the software update.
I am running 7.8.2.4 and have an iphone 3 which works well but has a very cracked screen so bought an iphone 4. This works ok but the wheel don't appear. What could be wrong?
Is there a new list for compatible screens as everything seems very out of date?
Hi, I have a Jester ML48 in as a temp desk as our Solution is having a service. I have got my LED fixtures set up but want to be able to put each colour onto a submaster so they can be mixed live but when in run mode the colours just snap change at 5%. I want them to work like the dimmer channel. How can I do this? Thanks
Hi, will this app run on a windows phone? Is it possible to get a copy of the old remote software as I just want to be able to use it as a riggers remote on a Solution?
Hi, sorry if this has been covered before but a couple of questions on remote: has the password issue on the solution remote for PC been sorted yet? is it going to be possible to recor, edit and playback cues from the remote? Thanks, Simon
