SimonH
4
Everything posted by SimonH
Will it ever be possible to have the outputs and cue list on separate screens?
Ok great. TBH it doesn't really affect me as I just want to use the capture software to plot in the daytime! It works well for me that way. I originally thought that once the flx took control the capture control stopped working, it wasn't until I saw the tutorial that I thought there might be an issue and it might help others if I raised it.
No, the controls in capture are not correct and don't control the lights properly.
Hi Edward, I'm running the latest phantom download for these tests. I had the same experience on the flx yesterday at work. I've rechecked the patch and all seems ok, so not sure what I was looking at before. All the controls from the flx work as they should and the outputs look correct, it's the controls within capture that don't correspond or change regardless of light position. If I try to use the focus position in capture as you showed us the lights just point in random directions This was the result of a single mouse click with the focus tool. You can also see that according to capture the light should be blue even though flx is outputting white. It all returns to normal once phantom/flx is disconnected.
I've just loaded the same files onto my old laptop that is running a registered version of capture and the same thing happens. Another strange thing is that if I click the focus in the same place multiple times the light never goes to the same place and the pan tilt details in the capture panel never changes.
Ok, I've got the correct files loaded now thanks but the focus method doesn't work still and the fixture info doesn't match. This is the same problem I'm having with my show file.
I have downloaded all 3 of the sample projects from both zero88 and capture and non of them work together properly. The channel numbering is all wrong and the focus talk back from capture to flx doe not work the same as Edward showed in the zoom training yesterday! Not sure what I'm doing wrong.
Hi, I can't find the sample files that work with the capture demo files. The links on old topics don't work. Thanks.
Hi, anyone tell me how to change the move on dark times for a cue that’s recorded? I’ve altered the default but it hasn’t changed the existing cues. thanks, Simon
+1 on the UNDO function especially record for me.
So how do you achieve PARK on a FLX desk?
Hi, a few releases ago you updated the filter picker to include white, are there any plans to do this for amber and lime?
Something similar to the @copyfrom from my old strand days
is there a way, using remote, that I can view the cue list of the main playback whilst the desk is in the macro playback?
exactly what I needed thank you!
so my software can do basic MIDI channel messages (Note On, Program Change etc) but not MIDI Show Control so is it possible with these to just trigger a GO on the main playback?
Hi, any chance someone could tell me in idiot terms the midi instructions to trigger GO in the main playback. Going to use CTRs Show control. Thanks
That's a shame. I always save my show file but might make a few changes as the show is running. Too much of a faff to save after every change. Can you copy cues between different playbacks?
how do we undo a cue update that was done in error? can a single cue/group of cues be recalled from a saved show if a overwrite was done in error? Thanks
did the universes show up in green on the LHS?
