codebone
Posts posted by codebone
Hi.
I run a small university production crew and we have two Frog2 consoles. Every single time we have taken them out in the two months we've owned them, we have had to perform hard resets on both desks because they would lag uncontrollably and/or freeze entirely. The desks always freeze when performing the most elementary functions possible, like raising a single dimmer, playing a cue, pressing the *group, beam, position, effect etc...* button or opening a window. Last week on a simple four hour event the console had to be rebooted 5 times throughout the evening. As one could imagine, this is not exactly ideal when working live productions.
The consoles are both running ZerOS 7.3. I have been unable to update to 7.4 because the dedicated zero88 flash drive that was provided is only 32mb while the update is 62mb, and no other flash drive that I install the update to will be recognized by the desk.
I enjoy the Frog2 surface, but If it can't perform in the most basic of settings then I will reluctantly have to get rid of them and move to a more reliable surface. That is not something I would like to do, but would have no other choice unless a solution to these issues arises. I would appreciate it if someone could shed a little light on why this might be happening.
Thanks so much.
I can't change the IP address. It doesn't allow setting of an arbitrary IP, it only allows the selection of already existing network devices.
I hadn't tried on any other version besides 7.4.
The settings on network > capture are "Enabled" and "127.0.0.1" for the IP address.
On a side note, using the physical frog2 desk, capture detected the universes over Art-net but not citp.
Hi all,
I just installed the new PhantomZerOS v7.4 software on my Windows 7 x64 machine. I am trying to get visualization with capture running now. I enable citp transmitting on 127.0.0.1 (local loopback IP) and it begins to transmit. Then I start capture and The desk crashes. Capture is set to automatically select which network device to listen for data on.
So I guess my question is, how do I setup visualization with capture using ZerOS (frog2 surface).
Thanks
Frog2 Crashes frequently
in Frog 2
Tempe, Arizona, USA (Arizona State University)
0087000-XXXXXXXX
0087000-XXXXXXXX
2 USB Ports on the front
New.
