Have spoken to Keith Rogers about this. Went into edit mode and discovered what is already a known fault in that if you edit a memory and that particular memory is also displayed in current memory and next memory, the lights on stage dip momentarily (a problem if you try and edit during the run). This is going to be fixed but it did lead me to a further anomaly which was new to Keith. I was looking to see if there was a top set feature as found on the Sirius 24 and 48. (Apparently there isn't).
However I managed to create it. It seems once you have been into and out of Edit Mode, then if the flash key beneath a fader is held that fader can be brought down to zero (or any other level). If you haven't been into edit mode this won't happen. Has anybody else found this one. I think top set is useful if you have an errant light but this way of doing it was not intended and so the feature does not officially exist. Could some way of temporarily reducing the level of a channel be included as a feature
