sicole
Everything posted by sicole
  1. Hopefully this works! Any problems let me know Showtec_Pixel8.ift
  2. Hi Anyone made a fixture file for the Showtec Pixeltracks for Fat Frog? I know there is one in the main library but thats for the the whole unit. I need one that will address all the segments individually so its all the parameters multiplied by 8 as there are 8 sections per pixeltrack so 48 total channels Kind of need these urgently so going to start playing with the fixture editor now. If I sort it I will post here Thanks! Si
  3. Yes I do Thanks - Si
  4. Hi Currently running 2.15 on the desk and have downloaded version 3, followed the instructions given, the installation program erases the USB pen drive (I am using the Zero88 supplied one), copies the software onto it, when I power up the desk, no matter what USB port I use, the desk does not boot into the Software Update Application it just hangs at the initial splash screen with frogs jumping around the displays. Have tried this several times - any ideas guys and how I can update the software? Thanks - Si
  5. Hi Paul Unfortunately we didn't we just had to get the desk working in a short time frame as always. I thought about it after we reloaded it. Thanks - Si
  6. Similar to the ghosting issue but not quite .............. We went to a customer's theatre this week to investigate a dimmer problem and found out it was actually the desk. Its a Fat Frog running 10.4.1. Channels 21 and 22 and 43 had values assigned to them when no subs, no fixtures and no presets were up. Only the GM would bring the values down. We reset the DMX outputs, cleared everything and reset the patch to no avail. Fearing the worst, I decided to reload the software 10.4.1 and this cleared the fault. Just for everybody's edification, does Z88 or anyone know what would cause this issue and why a software re-install would fix it? Thanks and regards Si
  7. We have 1 x Betapack3 thats playing up. Unfortunately the customer is 35 miles away and dont relish the prospect of going there to find its goosed and have to go there again to replace. Symptoms are: Channels 3 and 4, 5 and 6 work as expected Channels 1 and 2 are not working at all either through DMX signal or though the manual control on the pack The linking bar is my first point of call, Is there anything else I should be looking for when on site? Cheers
  8. At the time I was entering the channel value direct into the program window. The delay time is correct (about 2-3 seconds) I just should be more patient, but when you against the clock every second counts! Perhaps this could be an option in the Setup part of the LeapFrog rather than a hard and fast delay time as different people operate in different ways. Thanks Si
  9. We have v2.15 Leapfrog 48/96 Noticed last night as I was editing memories that if you wanted to change an intensity to say 55, you cannot type in 55 using the MFKs. Have not tried with keyboard though. It is the same for any number 11 - 99, although tempo times for chases allow you to do it. Also, in the memory stack, you cannot input step 55 or 44 or 33 etc it does not like repeating numbers. Just thought I would share that with you! Si
  10. As the whole thing says, "How Do I Topset?" Is there a way to do it on the new desks or could this be a feature in later software releases? It is such a pain when one lamp blows and leaves 1 or 2 on the same circuit still on, whole thing looks uneven. Here's hoping .................. Si
  11. Yes, certainly could be related to that. I dug a bit deeper on Saturday night and the fade down on that memory was nothing, hence transferring it to the sub would replicate the problem, but as I run through the memory stack, the tracking eliminates this. I cannot be certain but I am sure it had a fade down time of 0.0 at the start of the week. Other chases I programmed at the start of the week had the same properties and were fine. The only thing I changed on the setup was the flash/solo setting to try and get it to solo the chase but that didnt work as I found out from a previous post! Peter - I cleared the desk on Saturday so unfortunately do not have a show file. Thanks for your help Si
  12. Not even sure how and when this happened, came to the show yesterday, in the memory stack there is memory number 9 (a directly programmed chase). Fade up time is 0.0 sec, fade down time was 0.0 but is now non existent. Also, this memory is copied to a submaster. That had the same fade times. Erring on the side of caution I bypassed this in the show. After the show, tried it and once that memory or sub is outputted, you cant get rid without deleting. Any else seen this and how can you program in a fade down time when it displays nothing in the column? Off now to the show and to reprogram the chase Cheers Si
  13. Thanks for confirming I am not quite mad yet. I have programmed chases directly onto the subs but I was testing out the theory with transferring! What about the reverse scenario then? Programming a chase on a sub and transferring to memory - does that work with no bugs? Cheers
  14. Seem to be quite active on here at the moment! Right, we have setup approx 10 subs on the Leapfrog 96, all work fine. There are 7 subs directly programmed as scenes, and there are 3 subs as chases that have been transferred from memory. If we are to name those subs and change the fade times, when we switch the desk off and on again, the name goes back to Submaster 1-26 for example and the fade time changes (to what we think is the fade time of the memory but didnt get time to check that out). Is this a known issue? Thanks again! Si
  15. Thanks as ever - the solo issue is particularly annoying so hopefully that will change sooner rather than later! Thanks again - Si
  16. Me again! 1. Programmed a submaster directly and changed the setup of it so that the flash button when pressed solos the sub. It works when using outputs on the preset masters but when the playback master is outputting, it does not solo. How Do I ....... ?! 2. Is there a way to jump back to a memory like you used to do on the Frog? 3. Is there a quick way of getting back to the top of the memory stack? Thanks again!!!!!! Si
  17. Seems to work OK now. When I got to the desk today, Smart Tag was enabled and Cue Only was too, so the whole stack was programmed in this way. Cleared everything, started again with Smart Tag only on and works fine. Thanks Si
  18. Hi Peter, Thanks. Pretty sure we have 2.15 as we have smart tags. (not at the desk right now) One thing I did notice was that Smart Tags and Cue Only were highlighted as we were programming. Is that the recommended way to go or not? As I understand it from playing around, Cue Only would just record the state for that cue alone without affecting the tracking. When you say "output it", do you mean on the submaster or playback fader, or do you mean loading the already programmed memory? Thanks again, one day I really will read the manual (or come to a training day!) Si
  19. Just came back from the worst tech rehearsal ever. Using our new Leapfrog 96 with the manual (!!!!) some things just dont sink in. 1. I understand about tracking, I have no problem with the concept. However, assume I am programming the stack and I have program number 2 called STREET SCENE and that same scene happens later on say at program number 24, how can I copy into 24 from 2 so they both look the same? 2. Can you also use a mixture of submasters and preset faders to program a memory cue? If so how because ours just would not take it. Although I admit, time was pressing as was last orders! 3. Also, is there a way to turn tracking off? Just in case Both of these are fairly straightforward, but the manuals seemed to lack answers to our questions. Many thanks as always Si
  20. Hi I need to reload my OS with version 10.4. I know 10.8 is the updated version but reading the issues with tracking, I don't want it. Is there a link to older software releases? Many thanks Si
  21. sicole
    Info on Chilli's
    Hi Just wondered if someone could tell me the difference between all the different versions of Chillis that are out there. Have checked out the manuals but cant find a definitive answer anywhere. Basically, I am looking at it in the context of supplying a venue with 48 or 96 channels of dimming capability over DMX. Many thanks Si
  22. Hi Programmed a show on Monday night and then powered down. All was well on Wednesday when I powered up, finished the programming ran the show, powered down went to the pub. Came in yesterday, the changes I made were not saved. Any change I now make either to an existing program or if I program a new memory or sub are lost on power down even though I still retain what I programmed on Monday night. Any ideas guys? Thanks - Si
  23. Hi, I am looking for a set of rack ears for a Betapack2. Do Zero88 stock them as accessories or anyone know where I can get hold of a set? Thanks Si
  24. Hi, Hope I am in the right area, I think the Sirius 500 is a discontinued product - I am sure someone will tell me! Looking for a flightcase for a Sirius 500, wondered if Zero had one available as an accessory or anyone knows of anyone who makes them? Cheers for the help Si
  25. Thanks for your reply. I seem to recall doing that last night (did a lot of button pressing to no avail!). From memory, if I pressed BEAMSHAPE, I got nothing - no option to change the lamps on the wheels. Until I get on the desk tonight I wont be able to check - I am programming in Partial would I need to tag the fixture first? Thanks (again!!) Si
