donato
donato's Achievements
Newbie
Newbie (1/14)
  1. Ok, Jester is upgraded... I loaded 3 memory sticks with the Jester Software, but this time the first try was successful. I have no idea why it did not work before.. Thank you for your help! donato
  2. nobody has an idea!?
  3. And hw do I get the version 3.2?? I'm not able to download it, because only the version 3.4 is available on the support site! It will be nice to put a link somwhere to download older versions, i'm sure there will be more people who will run into this problem...
  4. Hi thank you for your tips. First i also thought that the memory stick could be the problem, but i tried 2 different ones: a 2GB and a 512MB.. So I will try to upgrade it to 3.2 first and then to the actual version. I post the results as soon as i did it donato
  5. Hi I have a Jester 24/48, but it still have the software version 2.1, so i tried to upgrade it to the current version 3.4. I downloaded and unzipped the OS to the root directory of a USB stick, which is fat32 formatted. Then i did the upgrade as described in the instruction document. The problem is that the jester didn't recognise the .jos-file on the memory stick. It is always complaining that there is no .jos-file on it. I tried the procedure with two different sticks, with the same result at the end.. What am I doing wrong? Or is it not possible to upgrade it directly from 2.1 to 3.4? Thanks for your help donato
