51
Everything posted by Jon Hole
Transfer or copy of a submaster to the memory stack
Jon Hole replied to james's topic in Leap Frog 48 & 96
I've listed this as ZerOS 3201, and we'll discuss the possibility of putting this into a future update. -
Looks like you're going to have to turn Tracking back on, doesn't it James You are right, as long as the lanterns from the previous cue aren't involved in the next cue, they won't get affected, and will continue with their fade, even if you GO with the next cue.
Hi Kresten, I have just made the fixture personality for you - please find it attached. I hope this helps. Jarag.ift
Hi, We provide the tools to make these on our website. Click here to download the Fixture Tools (direct .exe) Click here to download the User Guide (direct .pdf) If you need further help making these, please get in touch!
Thanks for this report - we are looking into this and let you know.
Hi Kev, At the moment, when the alarm is activated, the chilli's take all channels to 80%. If you want to replay a scene memory, you need a 'Chilli Net Bridge'. This connects between the Chilli and the Fire Alarm, so you connect the fire alarm to the Chilli Net Bridge, and then the Net Bridge of the Chilli itself. The part number for this is 01-210-00. Hope this helps,
Yes, a snapshot is effectively a block cue. You can also turn off move in dark per cue, by going into the comments section of that cue, clicking 'Macros...' and selecting / deselecting Don't move Colour / Beamshape / Position.
Hi Dan, Are you pressing 'EDIT' before changing the time, and then pressing 'EDIT' again after to confirm this? Once you have recorded a cue, you have to be in 'EDIT' to make any changes, including the fade times. It is possible to change the fade time before recording a cue or submaster too. Cheers
I'll look into this for you. Is everything else saving, such as cues, palettes etc? Are you running in tracking or none tracking mode? In none tracking mode, the desk won't record a fixtures parameters if the intensity is at 0. This is to allow the desk to 'move in dark'. Try ensuring the desk is in tracking mode, and then taking a snapshot of the outputs. This records EVERYTHING, whether you have changed it's setting or not. The syntax for this is SHIFT + RECORD. I hope this helps,
Can you either attach your personality file, or email it to me on the address in my signature, and I will have a look at why it's not working for you. Many Thanks
Remote/monitor - windows 7 - Bugs/suggestions
Jon Hole replied to lxkev's topic in General Discussion
Hi lxkev. We've noticed this too - we've listed it as issue ZOS-3192. We'll look into this - I'm not exactly sure what magic Windows is doing 'behind the scenes' in compatability mode, however I'm sure our software guys do! The monitor is limited to 1024 by 768 due to the output of the VGA on the desks themselves. We are wary of the remote being used to playback cues. For example, if your wireless network drops out you then have no control of your show. The ability is there to use 'panel' view with the cursor. This has been requested by another user on the forum, and is listed as issue ZOS-3187 'Command Line via Keyboard'. Could you send us a screenshot of this? For me, it's displayed as a useable size. I hope this all helps - thanks for your feedback. -
Hi Gareth, You would have to do this as a chase, which you could then link into your master cue stack. Changing 'direction' to 'random' might help create the flickering effect.
Hi Florian, As long as the two dimmers are connected using ChilliNet, you only have to plug the rs232 node into one of the dimmers. I hope this helps,
Thanks for making me aware of this! I have updated the original list on the forum, which can be found here: http://support.zero88.com/forum/index.php?showtopic=3913
LeapFrog (48) ZerOS 6 and View/Desktop
Jon Hole replied to Carl Ehrhardt's topic in Leap Frog 48 & 96
In a future update, we are looking at adding a 'screen' option into the Leap Frog 48 & 96, which would then allow you to move windows across the multiple desktops. This is detailed as issue ZOS-3197. -
Hi Russ, No, at the moment there is no way to make all the Playbacks into Submasters by default. This is something we have built into the ORB XF that is released later this month. We've set up Macros to do this before, and then saved the Macro onto a UDK. Be aware that Macros record the actual key presses - for example the Macro would record that you pressed the third syntax key, not the {page} syntax key.
Hi Carl, At the moment the Leap Frog 48 & 96 are limited to the one desktop and view. You can record macros of different screen layouts (by recording you opening the windows), which is the best work around at the moment. This is something we are looking into expanding. -
Thanks Eric, I have passed this on to be looked at. Please let us know if you have any further problems. Jon
I've added this as issue ZOS-3196 - we'll discuss the idea for a future update :-)
We will be looking at doing this in a future update, but I've added it as ZOS-3195 - thanks!
Hi Rookie, This is the normal behaviour of the Jester 12/24 - when you change pages any active submasters continue to stay on the pages they were at until they are no longer active (@ 0) and then switch to the new page you have selected.
I've logged this as issue ZOS-3191 and we'll look into why it's no longer working. This is an ORB and Frog 2 feature, that we are looking at adding to the Leap Frog 48 & 96 in the future. For now, however, you can only view Desktop 1. Unfortunately this is a bug that slipped through the net. It's already listed as issue ZOS-3190.
We're looking into it :-)
Ho Tommyb, I'm guessing you are selecting 'Update Fixture File'? You need to select 'Load User Fixtures' instead. Hope this helps?
We are currently running a promotion on twitter to give you the chance to win a free copy of the ZerOS Remote 2.0 for iPhone, iPod Touch and now iPad that has just been released in the App Store. For more information, please follow us @ORBdesk.
