36
Everything posted by Jon Hole
Hi Dan, There's a possibility that the flash memory card isn't seated correctly in the console, if it's had a bit of a bump or something similar. If you are happy to, it might be worth opening up the console and checking the flash card is pushed into it's reader correctly.
Hi Dan, There is a very long list of future developments for ZerOS. Additional functionality to support fixtures with multiple RGB parametres is one of them. Regards,
Selador Desire Vivid + Colorado 1 Tour Fixture Software
Jon Hole replied to JRTLeech's topic in Leap Frog 48 & 96
Hi, Both of these are included in our new Fixture Library release: http://zero88.com/forum/topic/6370-zero-88-fixture-library-release-24/ Regards, -
Hi Danno, Have you saved your show to USB? By doing that, at least you know you won't loose anything! Try going in and out of SETUP, as this forces the console to save onto the flash memory, and then reboot and see if it you loose your show. On boot, do you see any NVR errors listed?
Hi Sam, Here's the fixture profile - it has a slightly strange method of control, so let me know how it works (it's very hard without having it in front of us!). The website, product page and manual all used different names, so I've just called it 'DMX Starcloth'! Regards, LEDJ Starcloth.ift
How have you connected the ORB and your Laptop? If it's with a single cable, are you using a crossover cable?
Display Output Window & Memories Window on one screen
Jon Hole replied to awillimont's topic in Leap Frog 48 & 96
When you open a Window, you can press 'Special' and then you get 'Select', 'Close', and 'Size' on the MultiFunction Keys. Use 'size' to change the size and location of the window (press it several times and it will cycle through the options). -
Can't Edit Memories since upgrade to 7.4.0
Have you got the Leap Frog 48 or 96, with USB, or the Leap Frog with Floppy Disk drive? On the Leap Frog 48 & 96, you have to 'catch' the channel by taking the channel's fader to the percentage that it's at, and then you can take the channel to whatever percentage you require. So, If the fader i at 0%, but the channel is actually at 50%, and you want it at 30%m you have to take the fader to 50% or above, and then back down to 30%. If this isn't quite your problem - please email me your show file to the address in my signature below. Hope that helps, -
Hi Bob, So in PROGRAM mode, select one of the chase submaster so it's highlighted in yellow, and then press 'edit'. This will output the chase so you can see it on stage. On the multi-function keys and wheels, change the chase settings to the speed you want, and when you are happy press 'edit' again to confirm. Repeat this for the second submaster, with the different speed. Now, in RUN mode, your two submasters will work with different speeds. Hope this helps,
We don't have individual channel products unfortunately, so you'll have to use one of the 4 channel HF Chillis
Hi, The Chilli HF isn't a conventional dimmer, so this isn't possible. Each channel consist of a relay and a low voltage output that can be globally set as either 0-10v or DSI . Best Regards
The negative number after a timefade is saying that there are no parameters programmed to change during that cue. So if the fade up / down times have negatives after them, it's saying that no intensities have changed since the previous cue. In the same way, if the colour fadetime has a negative, it's saying that no colour parameters have changed. I hope this helps,
Hi Sven, Please find attached the fixture file for the Robin DLX Spot in Mode 1, 2 and 3 Best Regards, DLX.ift
Hi, The operating manuals for the Sirius can be found here: http://zero88.com/support/index.php?/Knowledgebase/List/Index/92/downloads Best Regards,
Hi, Sorry you had problems emailing me - I think my inbox might have been full. Please try emailing it to jon.hole@cooperindustries.com again. If that doesn't work, try support@zero88.com Best Regards,
- 6 replies
- futurelight
- fixture
(and 1 more)
Tagged with:
Does it have any more information than this? Would it be possible to either fax it or email it through to me? All my details are in my signature Regards,
- 6 replies
- futurelight
- fixture
(and 1 more)
Tagged with:
Hi Jack, Do you have the DMX breakdown for the PHS-150? I can't find one online. Best Regards,
- 6 replies
- futurelight
- fixture
(and 1 more)
Tagged with:
Hi billbayer, Please find the fixture attached - it includes all 7 modes. Hope this helps,
Hi Codebone, Have you had this working on any previous versions of Phantom ZerOS? What are your settings withing SETUP > NETWORK > CAPTURE? Regards,
No problems, any other questions just ask :-)
If there's no virtual dimmer, than they won't dim with the submasters. An option is to double click in the 'comments' section of that Submaster, click on 'Submaster Controls...' and then select 'Colour'. However, I would strongly suggest repatching them with a virtual dimmer, so they then fade with your normal intensity fades, and they will respond to the Grand Master, Blackout etc etc
Hi Mattdyas, Which fixture did you use in the fixture library to patch your LEDs? Regards,
Hi Paolino, Inside SETUP > DESK SETUP > MEMORY DEFAULTS you can turn tracking on and off. The difference between 'Tracking Basic' and 'Tracking Advanced' is that 'Cue Only' and 'Smart Tag' are both enabled in Basic mode. These can be turned on / off on the Multi Function Keys when you press 'special'.
Hi Doodling, First, you need to patch the LEDs into the console. Press SETUP on the desk, and then choose 'Patch Wizard' - it will take you step by step through what you need to do (select manufacture, select model etc etc). Once you've done that, click 'Auto Menus' and then select 'Auto Palettes'. Then come out of SETUP by pressing the SETUP button again. You can open the colour palette window by pressing SHIFT + COLOUR together, or you can type 'View 1 ENTER' which will take you to the palettes view on Desktop 2. Hope this helps,
