36
Everything posted by Jon Hole
Here's the fixture personality, with both modes. To use it, save it onto a USB stick, plug it into the console and then patch the fixture in the normal way, but choose 'USB' instead of 'Fixture Library' when selecting the source. Best regards, Chauvet Q Spot 460.ift
Hi JudgeAmyHost, There are a few different ways to do this. You can either start up one or more effects, make the changes to the size / speed / offset / rotation and then re-record this as an additional effect by pressing and holding a spare effect palettes (on the multi-function keys - remember there are the page buttons giving you a total of 400 effect palettes). If you want to create an effect from scratch, open the Effects Palettes Window (SHIFT+EFFECT) and then click the 'Effects Window' button in the top left corner. This allows you to specify specific waveforms to each individual parameter, each with their own size, speed, offset etc. You can 'fan' the offset across multiple fixtures by holding SHIFT whilst moving the wheel. To change the type of fan (Fan First, Fan Middle, Fan Last, Fan V etc) hold SETUP and press EFFECT and then change the 'Shifted Wheel Mode'. Hope this helps,
Hi, I've asked our software team to look into this for you, as I'm seeing the same thing in Non-Tracking mode (works fine in tracking mode). I've recorded it as issue ZOS-5469 Best regards,
Hi Huber, It's not possible at the moment, but this syntax has already been requested as issue ZOS-5370. You could go into Tracking Mode, make the change you want, and then jump back into Non-Tracking mode? Best regards,
Almost certainly :-)
Dan's method should work, but you'll also want to change a setting within the submaster. Go into the submaster setup window (hold SETUP and press the flash button of the submaster), choose 'Submaster Controls' and then choose 'Colour'. Now, the colour will be added as you move the fader, instead of being triggered at the trigger level.
Hi, When you take a channel up and then bring it back down, you've put '0%' into the programmer, so submasters and memories can't affect that channel until you clear the programmer (the programmer always wins!). Press the clear button, and then your submasters and memories should work fine? Regards,
No need - I've added you to our Beta Test group. You should find an extra forum within 'ZerOS Consoles' called 'Beta Test' which will have all the instructions and downloads. Give me a couple of hours... after lunch I'll upload a new version of software (7.6.23)
Hi Sfalken, I've been coming up with a very similar specification, but I can't promise this too soon I'm afraid :-) I think you will definitely find this over time. However, the processors are not as powerful in the Solution, so we can't bring you all the features of the ORB! We'll have to do some tests on Solution software to see what we can do. I think several people were in this situation, which is why we released the ORB XF with the 60 faders which can be Channels, Submasters or Playbacks.
Perfect, thank you. Added as issue ZOS-5441, our software team will look into adding support for this.
Solution Xl Desk Appears To Freeze On Initial Boot-Up
Jon Hole replied to mikeb's topic in Solution & Solution XL
Hi Mike, No problems. There is a possible bug that might be causing this, which has been fixed in the Beta software, so it might be worth giving it a go. Best regards, -
Hi Mike, OK, let's try another method of finding out what's going on here. If you open the system information window (listed under 'Other Windows' in the Output Window) the touch screen should be listed as a USB device. If you can copy the UID/PID from there, it may help track down what driver/kernel version is needed for us to support the Touch Screen. If you're not sure what you're looking for, feel free to take a photo of that screen (you might need to take a couple of photos, as part of the window scrolls). Best regards,
Hi Yattasin, I believe we've sorted this with you by email now? If that's not correct, please let us know! Best regards,
Hi Mike, Did you see the behaviour whilst running the beta software, or just whilst running 7.6.0? -
Hi Mike, Please can you send me a photo of this list? If you unplug the USB Keyboard and Mouse (so the touch screen is the only USB device plugged in) do you get anything in the list? If so, select whatever is in the list, and see if you get a load of text appear on the screen when touching the touch screen
You could create a macro that says: @@ RECORD ENTER @ . NEXT That would speed it up and make it very quick
Hi Mike, Thanks for trying this. Unfortunately the link you supplied doesn't appear to be working, and I expect they only had Windows drivers there anyway... which ZerOS doesn't run on. However, if it's possible to briefly install the Beta Software again, in SETUP> Desk Setup > Peripherals there's a button called "Input Capture". If you go into this screen, select the touchscreen from the drop down list, and then move your finger around the screen, we will capture all the data that the monitor is sending through the USB port, which will help us determine why your monitor isn't working. Ideally, move your finger right to the edges, and into the corners, so we can capture as much information as possible. There is a standardised protocol for touch screens (and two additional protocols for multi-touch screens) and we support all three of these in the latest beta, and have proved them working on other monitors. This suggests that BenQ aren't quite following the protocols somewhere. I'm not trying to shift the blame - they aren't the only one, and we've managed to add in patches for other monitors with similar problems, so hopefully we can do the same here! Many Thanks,
Hi Lars, Have you got any more news on this? Have you got any debug files? We haven't been able to recreate any of these issues I'm afraid - it's all working fine, apart from the one bug I mentioned above. Best regards,
Hi Huber, The 'effects' palettes and window are 'wave' based effects, whereas the 'chases' are step based effects Hope that clears things up
Hi Sfalken, There aren't any plans at the moment, so I've added this request as ZOS-5439 I've just replied to the topic: http://zero88.com/forum/topic/6561-edit-tracking-in-chaser-fixture-levels-window/ Best regards,
Hi Mike, Thanks, that would be great. If you have a few minutes after the show, maybe you could install the Beta Software and test the Touch Screen monitor. You can then backdate the software back to 7.6 afterwards if you prefer. Please let me know how you get on :-) Thanks
Edit Tracking In Chaser / "fixture Levels"-Window
Jon Hole replied to sfalken's topic in Solution & Solution XL
Hi sfalken, Thanks for the feature requests. The second one isn't currently possible either, so I've recorded them both: I've recorded your request to add the ability to edit steps in the fixture levels window as issue ZOS-5435, and to be able to get the tracking options directly from the console as ZOS-5437 Best regards, -
Hi, You can do this on a new cue stack. Select a new cue stack by typing STACK x ENTER Now, create 10 cues, Cue 1 with 1 at 100%, Cue 2 with 2 at 100% etc etc etc Then, click 'Stack Setup', choose 'Chases' and click 'Turn into chase'. When you do this, you'll get several chase settings appear. Hope this helps,
Hi Dan, If you are interested in testing some Beta Software, I can add you to our Beta Test group? We just released the first Public Beta of the software today. Regards,
I'm contractually obligated not to say. (Actually, I'm not, but it makes it sound much more exciting...)
