51
Everything posted by Jon Hole
Our list of compatible touch screen monitors is starting to look rather out of date: http://zero88.com/support/index.php?/de/Knowledgebase/Article/View/486/ There are a few ‘standard’ protocols for Touch Screen control and we support all of them, so in a perfect world – all touch screens should work! However, some manufactures decide not to stick with standards. For this reason, the only way we know if a particular touch screen works is by trial and error. If you use a Touch Screen Monitor with a ZerOS console, please post below which monitor you use, so we can update our list and help future Zero 88 customers. Many Thanks Jon
Hi Rob, Just look in the Sharpy manual to find the DMX values that have to be sent to remotely trigger a lamp on command, and then set those values on the wheels in the normal way and record it where you want in. Regards Jon
How To Get User Manual For Solution In French ?
Jon Hole replied to Laurent's topic in Solution & Solution XL
Hi Laurent, I’m afraid we don’t have a Solution manual in French. However, if you have any questions, please ask and I will do my best to help out. Alternatively, you could contact your French Zero 88 distributor – axente – who’s contact details are available here: http://www.zero88.com/distributors/westerneurope/france-axente.shtml Best regards Jon -
Programming positions @ zero intensity
Jon Hole replied to Bizureus's topic in Solution & Solution XL
Actually, "Smart Tag" functionality is enabled by default in Non-Tracking mode, and we remove the option to disable it. It shouldn't make any difference, no. Please could you send me your showfile, and instructions on what you are doing that isn't working (including fixture numbers, memory numbers etc) so we can recreate it here. Thanks Jon -
Hi Nappaoh, Sounds like you have 'Smart Tag' enabled - you can press 'Special' and turn it off on the Multi-Functional Keys -
Hi Wildswan, Each Window can be quarter size, so you can see four at the same time. Other Windows can then be behind these (and quickly brought to the front), or you can put them onto the other Desktops to quickly switch between. The output on the VGA is fixed to 1024 * 768
Hi Wildswan, No, there is only one VGA output on the console. The USB is used for Touch Screens, but they still need a VGA too. However, you can do this wirelessly using a tablet such as an iPad. You'll need to plug a wireless router into the console, and then connect to it with the tablet.
Hi GoPowers, The ones we use as Demo monitors, which we are really happy with, are the Iiyama T1531SR.
Where can I find the Jester ML Software 3.4 ?
Jon Hole replied to Specialworld's topic in Jester Range
Are you unzipping the file before dragging it onto the USB stick? Regards Jon -
Hi Jo, Do you require the 7 Channel mode? If so, which console are you running? Best regards Jon
Hi All, If you hold down SETUP and COLOUR together, you'll get a window with a "Colour Edit Mode" setting. Here you can choose the Colour Space you wish to use globally across the console - either RGB or CMY. This means you don't have to keep switching between CMY and RGB if you have both styles of fixtures in your rig. Best regards Jon
Hi dirkjan, The desk generates an unique ID from the device name, physical ID, and the unique ID, so it can match the calibration (and which display the touchscreen is connected to) on the next boot. If any of those change, then the touchscreen will need to be recalibrated. In the System Info window, under "Input Devices..." there is a line for each input device, with the filename, device name, physical location and unique ID. If possible, we need to check if any of the last three change at all from one boot to another (you need to turn off the touch screen too). Screenshots / Photographs of the screen after reboots would be good. It may be the touchscreen is making up a new unique ID every time it is powered on, which it shouldn't do.
Hi Jack, What version of software are you running? Are you in 'Tracking' or 'Non Tracking' mode? If 'Tracking', do you have 'Smart Tag' enabled? Best regards Jon
- 2 replies
- moving lights
- cue
(and 1 more)
Tagged with:
Hi Katie, Is the file saved on the USB when you open it? If so, that might be the problem? Make sure the file is saved on your computer, rather than on the USB stick, and then try opening it. Which version of Windows are you running?
Ahh I see the problem here... you've got the old Leapfrog console, not the replacement Leap Frog 48 console. Which version of software are you running?
Clear Patch does not clear the MFKs
Jon Hole replied to keredyelesob's topic in Solution & Solution XL
Hi, I assume you are talking about SETUP > Clear Options > Clear DMX Patch ? It's the 'DMX' part that's important here. This option is NOT for deleting the fixtures, it's deleting the DMX Patch associated to those fixtures. To delete the fixtures, go into SETUP > Patch > Edit Fixtures, select the fixtures on the MFKs (you can hold the first one and tap the last one to select all the ones in between) and then use the 'Delete' button on the monitor. Hope this helps, -
Hi, You can change this setting by pressing 'Special' and then choosing 'Flash Mode' on the Multi-Functional Keys (MFKs). It should be on the top row, third button along. You now get the choice between Flash, Solo, Latch and Off / Select. This shouldn't have changed with the latest software, and we default on 'Flash', so it suggests someone has changed this setting. When you say on/off - do you mean the light itself, or just the LED on the flash button? If the latter, that means that channel has been selected. This happens when the flash mode is set to 'Off / Select' or you press the flash button whilst holding SHIFT, which could suggest your SHIFT button is stuck down (or being pressed down on an external keyboard maybe?). Best regards Jon
Hi, Please find the fixture attached in both modes. Cyberlight CX.ift Please check it, and confirm we have got channels 10 and 11 correct as it's not very clear which is which. Best regards Jon
No problems on asking lots of questions! You can set the 'start address' which will renumber everything sequentially, starting at whatever number you enter, or you can go into the patch and number each channel individually.
Hi, Sorry for the delay in our "official reply" to this one. Yes, if Smart Tag is enabled, there is a bug where all tagged parameters will be recorded into palettes, not just the parameters in the attribute you are recording. There will be a fix in the next software update which we are currently testing.
- 14 replies
Hi Simon, If multiple channels are responding to a single fader, even after a software update, it sounds like the DMX address has been reset on one of your dimmers. Check the addresses on the LCDs of your Chilli Dimmers. If the first one is address to '1', and is a 24 channels dimmer, it will require use of 24 addresses, starting from 1 upwards. This means the next dimmer should be addressed to '25' to ensure there's no overlap. Hope that makes sense?
We're on 7.8 now, so as Ian says, Version 6 is quite old now and there have definitely been several developments made in this area which improves speed, functionality and overall performance.
