Jon Hole
Everything posted by Jon Hole
  1. Hi Ziglight, Other parameters won't always default to 0% (pan and tilt for example), so this becomes quite a bit less user friendly than intensity. The best way to do this would be to patch the fixtures in the normal way, and then record just Pan / Tilt / Colour onto a submaster (ensuring nothing else is 'tagged'). You can then change the "Submaster controls..." options within the submaster setup window to proportionally control that parameter. Best regards Jon
  2. Make sure you are looking at the "Output Window", not the "Programming Window".
  3. I've asked our software team to look into why this isn't working for you - reference ZOS-5845
  4. Thanks, I've added your comments onto our system (ZOS-3187) to be considered
  5. Hi ziglight, If you press "Special", go to Page 2 and then press "Show Command Line" on the multi functional keys, this functionality will work for you. Best regards Jon
  6. In the Output Window, there is a button called "Source" - if you press that, instead of telling you the intensity, the Output Window will tell you why the fixture is at that intensity. What does the 30% change to when you press Source?
  7. Hi Ziglight, We have a list ready to implement in the future, but at the moment not really. One that's useful - Shift + F10 will take you into SETUP. This was included for internal use, which is why it's not advertised or particularly obvious! Best regards Jon
  8. Hi tompockets, This isn't currently included in ZerOS, but there have been a couple of requests for this feature now.
  9. Added a comment to ZOS-3849, related to "Window Cloning"
  10. Hi, Here is the fixture you require Geyser.ift For completeness, here is the Chauvet COLORado batten 144 too. COLORado 144.ift Best regards Jon
  11. Hi Charles, Does the Output Window of the fixture say 30%, or does the console think it's at 0%? Best regards Jon
  12. Hi Ziglight, There's no special reason. In the software, the wheels are numbered 1 (left), 2 (right) and 3 (thumb), so this is why the are spread out like this, unless wheel groups are created. However, only some profiles have fixture groups. However, we're preparing a big update to our library and this issue will be fixed. However, I don't have a release date for that yet. Best regards Jon
  13. Hi Kirk_sim, Are you running Windows 8.1 too?
  14. Hi Ziglight, You should have just received an email from me - if you haven't, please let me know. Best regards Jon
  15. Hi Ziglight I've added this as ZOS-5805. Currently, there is no way to change the default settings for a chase on the Solution (there is on the ORB, as chases work in a different way, so the issue is to bring those settings across to Solution). Best regards Jon
  16. Hi Peter, Thanks for the request, I have added it as ZOS-5804. Could you define what you would expect from the "Shake" functionality please?
  17. Zero 88 Fixture Library Release 27 For full information, please visit: http://zero88.com/software/library This release contains 3864 fixtures from 219 different manufacturers. For a list of fixtures in the library please click here. The library is released in 2 formats: a full unfiltered version for desks running ZerOS software (ORB Series, Solution series, Frog 2 and Leap Frog 48 & 96). a smaller filtered version for other Zero 88 desks. This removes data that is not used by these other desks, so that the file is smaller. When using a floppy disk (original Frog series, Illusion500) it is recommended that the floppy disk be freshly formatted before using it. Download & Installation The correct format of the library for your desk can be downloaded by clicking the product name below. The library (.ift file) should be placed in the root directory of the floppy disk or USB stick. ZerOS desks (ORB Series, Solution series, Frog 2 and Leap Frog 48 & 96) The latest fixture library is automatically installed on the desk as part of each operating software update, however this can be updated from USB if required in Setup -> Files -> Update Fixture File. JesterML & JesterTL The fixture library is installed on the desk at manufacture, however this can be updated from USB if required in Setup -> Update Fixture Lib -> Update Library. Frog Series and Illusion 500 Use 'Common Fixture Manager' (included in the Fixture Tools download) to select the fixtures you wish to use, and save this as a file to a floppy disk. Diablo The fixture library is used with the Diablo Fixture Manager PC software. Sirius 250/500 Use the Fixture Type Editor to import fixture types from the fixture library, and then use the ‘Export Sirius UFT’ function (under the ‘File’ menu) to generate data in the correct format for the Sirius 250/500. Further details of assigning fixtures on the desk to fixture types in the fixture library can be found in each desk’s operating manual. Additional Fixtures If you need a fixture type which is not in the library, then you can create this yourself using the Fixture Type Editor. If you post a link to the manufacturers datasheet on the forum, we will endeavour to add the fixture in the next library release.
  18. There is already an issue open to add in this option, which is listed as ZOS-4780, so I've added a comment to say we've had another request. Changing the Colour Edit Mode between RGB and CMY doesn't just change the labels, it automatically makes the transition from RGB to CMY. Using the "faders" option within the Colour Window is quite a good way of showing the difference between RGB and CMY, as when you move CMY, the RGB faders move to their equivalent levels at the same time.
  19. I've added it as ZOS-5795 and will have a look into why that's happening :-)
  20. Oh, I see! Yes - you can do that. Press 'Special', press 'Time' on the Multi Functional Keys (MFKs) and then enter the time you would like to assign to the programmer. Holding SHIFT whilst pressing 'Time' (on the MFKs) will enable and disable this (LED will come on, and the background on the LCD will turn white). Hope this helps
  21. Are you aware of how to set Colour, Beamshape and Position fades per cue and submaster? Are you wanting to break this down even further, so different fixtures fade over different lengths of time? If so, this is available on the ORB Series of consoles, but not available on the Leapfrog 48&96 or Solution Series. I think you have an external keyboard plugged in? If so, press the '+' on the keyboard (not on the front panel) between each group and it will multi select them.
  22. Kind of - the idea within ZerOS is that as an operator you choose which colour space you wish to work in, CMY or RGB, and then we do all the work in converting everything to that colour space for you. There is Press SETUP and COLOUR together. In the window that appears, click "Colour Edit Mode" and change it from CMY to RGB.
  23. Update will update all values which are tagged. Most of the time, this is all values that you have changed, however it does mean it's unable to "remove" changes, just update them. On ORB Series consoles, there's a "remove" button within the update window, but this is currently not available on Solution.
  24. I'm afraid that's not available publicly. We give you a reference if you ever want to contact us about it again in the future, and the release notes will include this reference. There has to be a limit. If we raised it to 300, we'd just get a request to make it 400! There are only 2048 DMX channels available. Assuming that 48 of those are taken up by the faders, that's only 10 channels per fixture if you patched all 200 fixtures... so they are already limited to very basic fixtures
