50
Everything posted by Jon Hole
Have you got a proposal?!
Hi Dil, The Mambo Frog is not the most suited console for running 24 dimmer channels, but you can add dimmers onto the fixture channels if you wish. The manual for the console can be found here, and it should give you all the information you need. http://zero88.com/support/index.php?/Knowledgebase/List/Index/73/ Best regards Jon
odd behaviour with channels 14,16 and 33
Jon Hole replied to keredyelesob's topic in Solution & Solution XL
Hi keredyelesob, What version of software are you running? -
Yes, you will :-)
Hi Ben, New windows always open on Desktop 1. When you select or open a new window, you can then press "VIEW" on the front panel, and then on the 5 blank syntax keys (with the LCDs, above the numberpad) you can press "Size" which will rotate through all the possible positions and sizes. You can also choose "Select" to cycle through the open windows, "Screen" to change which screen it's displays on, and "Close" to close the selected window. I hope this helps. Best regards Jon
Hi Mattdyas, Are you able to give me some more information please? Which channels do you see this on? Is there a way to stop them flashing? Do you see anything in the output window for those channels? Many Thanks Jon
Hi pierotec, This is exactly what we're working on - giving you two separate apps for each of the functions, so you can choose which app to run, and on which device. Regards Jon
Hi timthetutor, If you Right Click on any button, it's the equivalent of holding it down. So, you can right click the SHIFT button, and then click and hold the MODE button for around a second. Make sure you then right click the SHIFT button again, so you are no longer emulating holding it down, otherwise you'll get some strange results. Best regards Jon
Hi Lightmaster, Sorry, I understand now. In each stack, go into "Stack Setup" and then click "Unblock". If you do this on all three stacks, I think you'll find it works. Best regards Jon
HI Clemens, We're going to be uploading a Beta version of the app soon, so it then depends on the feedback and testing! Jon
Hi Nick, SHIFT + CUE will open the cue stack window. Which version of ZerOS are you running? In older versions of software, it will only store the View layout every 30 seconds or so, so if you make a change to the layout and then restart quickly, that change might not be stored. A quick and easy way to "force" a save is to go into SETUP and then come back out. Best regards Jon
Fixture Request URGENT - Antari X-310 Pro Fazer
Jon Hole replied to SGSTEC's topic in General Discussion
Here you go :-) X-310.ift- 2 replies
- zero 88antari
- antari x-310 pro
(and 3 more)
Tagged with:
Hi Both, I'm guessing you're talking about the old Jester ML, rather than the Jester ML24 or Jester ML48. Your local Zero 88 dealer will be able to get these for you, they are part number 9074500 ("Rack Mounting Brackets").
This has now been uploaded. This only affects SCD Server & SCD Server Pro. The release notes are here: http://zero88.com/support/index.php?/Knowledgebase/Article/GetAttachment/366/835
Ahh, I didn't realise that was sent out today - it's on my to-do list to upload it tomorrow morning! It's actually been shipping on products for a while, there is no major improvements over 7.8.1. We're working on 7.8.2 which will solve your problems.
Hi, I'm guessing you just phoned the office, but just in case it wasn't you and this is coincidence, please find it attached. indigo 5500.ift Jon
LF48: Where can I find the "Desk Information" screen?
Jon Hole replied to Johnny's topic in Leap Frog 48 & 96
Hi Johnny, Yes - come out of SETUP, and in the Output Window, choose "Other Windows" and then select "System Information". We've combined 5 different windows all together in that single place now. For a full list of the changes, you can download the release notes from this link: http://zero88.com/support/index.php?/Knowledgebase/Article/View/366/156/ Best regards Jon -
Fixture File for Briteq LED MEGA BEAM and LED PIXEL BAR RGB
Jon Hole replied to AlexSky's topic in General Discussion
Hi AlexSky, ZerOS allows you to pick which colour space YOU want to work in, no matter if the fixture is CMY or RGB. The console will then convert from the colour space you choose to the colour space of the fixture automatically for you. There is a request to offer direct control of both CMY or RGB, which is on the to-do list! Jon -
Hi Jimmi and Mike, There are a few extra settings you'll need. Full information here: http://www.zero88.com/support/index.php?/Knowledgebase/Article/View/585/ Jon
It's always worth asking the question - all our developments are chosen from customer comments!
Yes, definitely. We're completely reworking it to bring a much more useful and improved app.
Hi Max, Yes, the colour picker only affects RGB or CMY currently. The reason for this is that the White and Amber channels across different fixtures can be a lot of different colour temperatures, so without calibrating every fixture, it's very hard to get the colour picker accurate (the same applies for Red, Green, Blue, but the variation isn't quite as much as it is with Amber and White). We have got an issue to see if we could implement this somehow, and we're looking into various options. Regards Jon
As I say, it's not going to do what you want, no. However, that doesn't mean it's not a useful feature!
