Jorge
Jorge's Achievements
  1. Hi Stupot, as you have got not more than 48 faders, you have to program your additional dimmers as "fixtures". You can control them by using the MFKs and the right wheel (choose "position"). To patch the additional dimmer to DMx-adress 49, you push the first MFK on page 1, if you are to choose a destination. After that, you can press MFK 1 again, hold it and press MFK 20, you patch automatically 20 new dimmers to the MFKs on page 1. Because of malfunction of output: maybe you have to raise the Grandmaster and Preset-A-Master? Hope it helps Jorge
  2. Hi Sven, thnx for your replie, but sorry: it´s not working. Maybe it´s different on the "Bullfrog", setting "LeapFrog" to HTP makes editing cues impossible and still all active outputs are killed by "Load". I keep on waiting ... P.S. Warum arbeitet Laubfrosch am Ochsenfrosch? greetings from Jorge
  3. Hmmm... As there is no more replie to my question, I think, LeapFrog 48 has no feature to give absolut presedence to some outputs. So this might be something to think about, Mr Kirkup and friends. My suggestion: a new feature that allows the user to give "submaster" preference to all other activities on the board. (sorry for my bad english, I´m german...) By the way: what about the idea of the possibility to push "GO" on an external keyboard? This has been discussed several times in the forum and for me it would be very usefull.
  4. Hi, you can try it with this fixture file. I created my own with 5 channels and changed it into 4 channels for your LEDs. Hope it works Greetings from Jorge LEDJ LED 64.ift
  5. Thanks for the hint, but I´m working on a LeapFrog 48, there´s no "merge"-button like on Frog 2. Maybe another idea?
  6. hello to everybody, i´m using HMI-lamps quiet often. once they get switched off, they need some minutes before they can get started again. my problem: adding HMIs to existing memorys. changing a memory by using "load" kills all active outputs (channel or submaster), so i have to wait quiet long before i can see the new scene on stage. using "overwrite" instead of "load" kills all the programmed times, which is not very helpfull as well. the only way i found is using "blind" modus, but that is rather complicated if you want to edit a number of memories. is there a way to keep special outputs active? by the way: thanks to the zero88-stuff for software 5.3. including non-tracking modus. it´s perfect for theater people. greeting from jorge
