csylten
Everything posted by csylten
  1. Im going to use these lamps this weekend, and would also like to have the file. Pls help
  2. Hi! Can you please help me make a fixture file for the Impression 120RZ ? I know the impression already is supported, but this is not the Zoom version.. Here is the manual with DMX chart. http://www.glp.de/in...push&docID=2925 or use the attached file Impression 120RZ RGB Manual V1.5 EN (2).pdf
  3. Used the Iphone/ipod remote softwere this weekend on a Leapfrog, it works, but why should it be so hard to use the app when focusing conventional fixtures? Is it possible to add a "focushand" function to the remote software? For example, a numeric keypad to press channel 1-512, and then press "enter" to set the channel to 100% ?? Or/and an "next" and "prew" button to brows between channels?
  4. bump?
  5. When I use the offset function the offset is shown in the display as 0-100%... BUT, when I use the shift button at the same time to "fan the offset", I cant read the % of the offset. why?? If I have 4 MH's and put them in 25% offset in fan mode, I have to look at the fixtures to know when they are "about" 25%. and... Is there an "auto-offset" function yet? ex. if I use 4 fixtures in an effect, and I want them to be set to the "perfect" offset for number of picked fixtures, 25%. Insted of manualy press shift, turn the wheel to 25% (if I can see when I reach 25% ofc.), I just set the effect, and press "auto offset", and the frog will do (100% / 4 fixtures = 25% offset) . . . ?
  6. Is it possible to make a "chase" or a rnd. chase on a ledbar, using the onboard effect generator? f.ex: put a sine or saw wave on RED1,RED2,RED3 and then set an offset so they go random?
