AoS Lighting
Everything posted by AoS Lighting
  1. Hi, I have a Fat Frog and I am trying to program a submaster just to strobe but since strobe is in the beamshape attribute with gobo, gobo rotate, focus, prism, etc...when I hit the submaster I have programmed to strobe it effects all the other parameters in the attribute. for example: If I am projecting my movers on the wall with a certain gobo and focus and I want to strobe but not change the gobo or focus (or anything else in that attribute). How could I program just the strobe value into a submaster? or: same situation, but I want to access the prism with a submaster and not effect anything else in the attribute? Any help would be greatly appreciated! Thanks, J. Gibson
  2. Great, Thanks! J. Gibson
  3. Hi, when I try and load the Matrix 575 personality I made it says there is no info on the disk. I saved it and loaded it the same as the fixture library I downloaded from the site which worked fine. I made sure it was an ift. file and I don't really know what else to double check. I've attached the file. If anyone could check it out for me and see what I'm missing I would really appreciate it. Thanks, J. Gibson MAT_575_personality.ift
  4. Hi, could anyone tell me what model Chauvet Q-Spots are in the fixture list? I'm am not familiar with Q-Spot M1-N, M1-Y, M2-Y, M3-Y. Do they just go in order: Q-Spot 152, 200, 300, 575?? Thanks, J. Gibson
  5. Ok, thanks. Could you tell me what model Chauvet Q-Spots are in the fixture list? I'm am not familiar with Q-Spot M1-N, M1-Y, M2-Y, M3-Y. Do they just go in order: Q-Spot 152, 200, 300, 575? Thanks, J. Gibson
  6. Thanks! I've made the personality for the Matrix 575 and I was wondering if it's necessary to put in the details on each parameter? Or will it work the same either way? If it is necessary, then what is the significance of putting in the "mid point" value? Thanks, J. Gibson
  7. Well, I got fixture tools and started making the profile for the Matrix 575s. I'm not clear on what attribute to use for the lamp control, speed, prism+macro, prism rotate, etc... Any tips on creating profiles would be greatly appreciated! I have very limited experience with boards, i've always used software. Thanks! J. Gibson
  8. I have a Fat Frog and am trying to assign Optima Matrix 575s and Chauvet Qspot 200s. I did not see the Matrix 575s on the fixture list. Is there some where I can find and download it? I saw several options for the Qspots but they were described as Qspot M1-N, Qspot M1-Y, etc. rather than with numbers (Qspot 200, Qspot 250, etc.) Are these the same thing? If so could someone tell me which one is the Qspot 200? Thanks! J. Gibson
