Pyro Bob
Everything posted by Pyro Bob
  1. Hi Paul Solution works perfectly. You are a legend... Graeme should give you a pay rise. Thanks Bob
  2. Hi Paul Attached are my files Regards Bob ShowFX3.ift
  3. I have just upgraded my JesterML withJML_24 and downloaded and installed FixtureTools2_1_0_0. I now have a problem with the JesterML recognising the Pan/Tilt Functions on a fixture that I have created. The fixtures were originally created with the previous version of editor and they worked on previous software. I have tried everything I could think of. I have even tried to modify an XSpot as described in previous posts. The JesterML will not recognise the Pan Tilt functions.
  4. I am having blank front pannel issues as well. I have just overcome this issue. These are the steps I used: 1 Switch off High Quality Scaling in the settings menue. 2 close all other applications. 3 Refresh Desktop 4 Log Off 5 Log On 6 Open Phantom Jester First 7 Open Front Pannel First 8 Open Monitor After this I was able top open any other application Boring but it works
  5. I am a big fan of Zero88 desks. I currently have 3 Jester 24/48 desks. Just took delivery of a new Jester ML. I also have moving fixtures which dont allow pan/tilt invert. I understand that this function is reserved for the larger desks. However would it be possible to add this function into Fixture Type Editor so that I can simply assign a fixture with the inverted functions?
