Hi iank99 & KWR88,  I have checked our keyboard and mouse current requiremants and these are 50mA and 100mA respectively. I would not expect these levels to cause any problems, but we could replace the optical mouse with a lower current demand version if you consider that necessary. Can you please give us your opinion about the max. currents permissible/advisable, as we could not see any limits listed on the Specifications in the Manual?  Thanks, Keith, for the 'heads up' about the wiring change on the remote socket of the old Fat Frogs. The Fat Frog we had was sufficiently modern to have the standard connections, so our existing cabling and remote switches are working without any wiring changes.
To help us make a decision about whether we have a new Solution which should be returned for investigation, or not, we would be interested to hear if others on the Forum have had Solutions which failed to load further than the initial picture on the first switch on? Did they then load properly on the second try? Finally were they being switched on at the AC mains supply switch, or by the switch on the back of the Solution?
Regards,
Gordon
